VideoHelp.com Forum
Results 1 to 9 of 9
    OK, I just installed the latest v.2.2.0.0 of ImgBurn (released 2/13/07), and when I click on the "Burn with ImgBurn" context menu shell extension after right clicking on a VIDEO_TS folder I get an error message stating that "ImgBurn is not installed" (I'm referring to Chrissy Boy's "ImgBurn DVD-Video Shell Ext").
    The new v.2.2.0.0 of ImgBurn is located in the same path/directory as the old v.2.1.0.0 was. I tried un-installing / re-installing ImgBurn and the ImgBurn DVD-Video Shell Ext (v.1.2) to no avail. When I uninstall the ImgBurn DVD-Video Shell Ext I am offered the option of Repair or Uninstall. If I run the Repair option I get the same error: "ImgBurn is not installed." If I do a total uninstall / re-Install of the ImgBurn DVD-Video Shell Ext, I get the same error message.
    The new v.2.2 of ImgBurn is working just fine, I just can't evoke it with the context menu any more. And yes, NET 1.1 & 2.0 are installed on this WinXP Pro machine.
    Any ideas as to what's wrong here? I really miss this convenient feature!
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You might check their site for suggestions if no one here has any ideas. http://www.imgburn.com/
    And this doesn't seem to relate to the SVCD2DVD forum. Moving you to the Computer forum.
    redwudz,
    I think you misunderstand. The problem is not with ImgBurn, but rather with the "ImgBurn DVD-Video Shell Ext v1.2" proggy which is authored by Chrissy Boy and can be found at the bottom of the SVCD2DVD home page: http://www.svcd2dvd.com/.
    I really believe this should be addressed on the SVCD2DVD forum as I would like this to come to Chrissy Boy's attention.
    Thank you...
  4. Mod Neophyte Super Moderator redwudz's Avatar
    Yes, I did misunderstand. Moved back.
    OK, Problem Solved!
    Uninstalled ImgBurn and the ImgBurn DVD-Video Shell Ext one more time, but this time I scanned the registry for every instance of "ImgBurnDVDVideo" and deleted same. Reinstalled ImgBurn 2.2.0.0 and the ImgBurn DVD-Video Shell Ext and all is working again.
    Registry problem... Go figure!
  6. Member ChrissyBoy's Avatar
    Thanks for the heads-up.
  7. Tried the above tips but I can't get it to work at all with 2.3.2.0 - any ideas?
  8. Member ChrissyBoy's Avatar
    well i have just upgraded from 2.1.0.0 to 2.3.2.0 and everything is fine...
    Maybe uninstall the ext. Do
    Then REBOOT.
    Then reinstall the Ext...
  9. Re-installed XP last night so will re-test with a clean install....
  1. ImgBurn Error "Logical Block Address Out of Range"
    By SoberWarlock in forum Authoring (Blu-ray)
    Last Post: 4th Dec 2011, 15:37
  2. IMGBURN shell ext query
    By nawo69 in forum SVCD2DVD & VOB2MPG
    Last Post: 22nd Nov 2010, 10:21
  3. IMGBURN shell ext - not working with Win 7 64bit?
    By CBC in forum SVCD2DVD & VOB2MPG
    Last Post: 23rd Aug 2010, 18:11
  4. Can't burn CDs with ImgBurn - "Incompatible Medium Installed"
    By Lawbringer in forum DVD & Blu-ray Writers
    Last Post: 11th Oct 2009, 16:35
  5. ImgBurn DVD-Video Shell Ext v1.2 & Vista
    By guidorobben in forum SVCD2DVD & VOB2MPG
    Last Post: 29th Sep 2007, 15:47
