I'm subbing a piece of anime using Aegisub. The original file is mkv, i demuxed the video so i have now:So i made this really-frame-accurate ass, went to zoomplayer and noticed that the times are shifted! Woah, but that ruins all my work since one frame can mean half a screen in some cases - and i was translating signs and other stuff, too.
- * AVI encoded with DIVX5
* OGG audio file
* ASS script that really is frame-accurate
Then i remembered I heared DirectShow is bad at precize timing. So i made an avs that would use AVISource to load video.. Woah, it works pretty fine - as desired! So I thought: if you can't do it the soft way, do it the hard one (since I don't know any other solution)
Now I want to make it as following: hardsub anime to xvid and make an ogm (since avi doesn't support ogg, at least i thik so). Another problem is in that the anime i am translation is not too silly and some things are very hard to explain to people who know nothing about certain aspects. So I wanted to add an option to choose an ass *WITH* explanatory notes - when i wanted to make an ass-ed mkv. Now I don't know what to do.. Should I make an mkv with both hardsubs and softsubs? Or should I just include a explanatory html file?.. Or maybe there is a solution that can help making the subtitle timing precize enough?..
What would you recommend?
Results 1 to 1 of 1
subtitles timing
By teamo1976 in forum SubtitleReplies: 3Last Post: 21st Dec 2009, 15:58 -
.ASS subtitle is in sync but showing at the wrong position
By onlinepen in forum SubtitleReplies: 2Last Post: 9th Nov 2009, 04:48 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05 -
How is .SUB timing calculated ?
By darconio in forum SubtitleReplies: 5Last Post: 12th Dec 2008, 08:26 -
Timing wrong on captured video.
By Jack_Dante in forum CapturingReplies: 1Last Post: 17th Jan 2008, 09:20
