VideoHelp.com Forum
Page 3 of 3
FirstFirst 1 2 3
Results 61 to 79 of 79
Thread: DTS to AC3 5.1
  1. Member yoda313's Avatar
    Originally Posted by pmshah
    It even managed some really troublesome DTS files where all else failed.
    Just curious are your "problem" dts files by chance dts-ma files from a bluray source? You could simply use eac3to and extract the core. Than it would be like working with normal dts files off a dvd. That SHOULD make it more compatible with a wider range of programs that might not recognize hd audio sources.
    Worth looking into if that might be the case.
    I never work with Bluray source. My experience was mostly with 2 channel DTS files that someone else had ripped. To make my files compatible with widest range standalone players and wide range of PCs my final settings generally are- 720p, 2000 kbps mpeg4 ASP video and 384 kbps 5.1 AC3 audio with DRC within MKV container.
    I have also had occasional problems with AAC audio which too this software handled beautifully. BTW is is more like gui front end for ffmpeg.
  3. Member yoda313's Avatar
    If it is you might look into winff as well since that utilizes ffmpeg also.
  4. in-line with poisondeathray response:
    following command-line will convert DTS -> AC3 5.1 ch. 448KHz DVD compatible.
    1) eac3to -input.dts -output.ac3 -down6 -down16 -resampleTo48000 -448 -quality=1.00
    use -down2 instead of -down6 for downmixing multi channel audio to Dolby Pro Logic II stereo.
    2) one can use BeSweet to convert 6 mono WAVs to AC3.
    3) With AVISynth use SSRC and SOX.
    Yes but this covers only the audio part. It simply accesses the DTS audio and gives you a 512 kbps AC3 file.
  6. I just purchased the LOTR: Extended Edition blu-rays and was having trouble with the DTS audio source. Specifically, I have been using ClownBD, MKVMerge, and Handbrake to create mp4 files with subtitles. Normally, I've been able to convert the DTS files into AC3 using ClownBD when demuxing, but couldn't with the LOTR blu-rays - I think this might have to do with the fact that it is a DTS 6.1 source. Any ideas on how to convert the DTS 6.1 into AC3?
  7. Member yoda313's Avatar
    Eac3to.
    Of course this might be a cenevia encyption issue. But I don't know the symptoms of it so I can't say for sure.
    If eac3to can't make a useable ac3 from it it may be cenevia.
  8. I tried Eac3to but it didnt work (using this method http://forum.videohelp.com/threads/3...-separate-WAVs)
    Any other suggestions?
  9. Member fritzi93's Avatar
    I just finished backing up my extended LOTR discs with (almost) no problem, using Clown_BD to extract main movie, converting the audio to 640 kps AC3, as I usually do.. Something else is going on with your computer.
    1) If you're going direct from disc, try ripping the disc to hard drive first, then extract main movie. After doing a couple discs, I tried to speed up the process by going direct from disc and Clown_BD bombed out halfway through. After I did the job the slower way, I went back and tried it again out of curiosity. But I haven't been able to replicate that problem.
    I suspect it's more likely that will happen when the destination drive is getting full and/or fragmented. I've seen that a couple times before, although the problem is not common. But these are rather big files after all.
    2) Since you've used Clown_BD before with success, it's unlikely you have a decoder problem. Nevertheless, if the above fails, try re-installing ffdshow and haali; I can confirm the versions tested by jdobbs and available on this page are stable:
    http://forum.doom9.org/showthread.php?t=143716
    Pull! Bang! Darn!
  10. Unregistered El Heggunte's Avatar
    An actual 6.1 DTS-ES has 7 channels, not 6. Try eac3to again, but this time by using the "-down6" option.
  11. OK i got it working now doing my own thing...works well enough for me at least
    I just separate the DTS into separate wav files using eac3to and then make my ac3 using wav to ac3 encoder
    Thanks for the suggestions!
  12. Member yoda313's Avatar
    That seems odd. By all rights you should be able to go straight from dts to ac3 with eac3to. I would suggest trying it again. You should not have to do the intermediate step of making the separate wav files.
    My experience tells me that the AC3 sound is always at a lower volume level then the DTS when converted. Some times I too have togo this route and use wavegain as an intermediate for boosting the volume.
    Mostly I raise the volume using Avidemux by eelecting Copy for video and manually setting 3 - 4 db gain for Aften AC3.
    Quite by chance I hit upon a solution that is now working just fine in all respects.
    I used to set the audio bit rate at 384 kbps and the volume level was never at DTS volume level. I had to resort to various other means to jack up the volume but it was always a compromise.
    While just fiddling around I used MKV2AC3 software and set the audio bit rate to 640 kbps, selected Aften under method, check marked AC3 normalise option and slid the slider all the way to right under Loud.
    It took a bit of time to convert but no where near my previous methods. Played both files - original and newly created and they both sounded equally loud without having to touch the volume control on the speaker system. The soft speech passages were now much louder and clearly audible.
    BTW I reaped another reward as a by-product. My 4 gb dual core Atom based mini-itx system used to have problems playing files ripped at 2.5 mbps bit rate. With this conversion I am able to play even files with bit rate upwards of 5 mbps.
    Originally Posted by Soopafresh View Post
    Download
    dts2ac3.zip
    Requirements -
    1) Avisynth
    2) .Net 1.1 Runtime http://fileforum.betanews.com/detail...1/1016688677/2
    Instructions
    1) Unzip dts2ac3.zip
    2) Rename your dts file to INPUT.DTS . Place in same folder as Dts2ac3
    It will look like this
    aften.exe
    BePipe.exe
    DTS.avs
    DTS2AC3.bat
    INPUT.DTS
    libaften.dll
    NicAudio.dll
    3) Double click on Dts2ac3.bat . AC3 file will be named OUTPUT.AC3
    That's it! Just make sure you install Avisynth and have .Net 1.1 runtimes installed
    It work very well, Thank you...
    Download
    dts2ac3.zip
    Requirements -
    1) Avisynth
    Instructions
    aften.exe
    BePipe.exe
    DTS.avs
    DTS2AC3.bat
    INPUT.DTS
    libaften.dll
    NicAudio.dll
    I have tried this tool too. Conversion is not the problem for me. There are any number of converters available that will do the job. The problem has always been the volume levels of the AC3 track within such converted file. All else remaining the same, AC3 audio ALWAYS requires increasing the volume via the volume control knob of the speaker system, that too quite a bit. This is very pronounced for the speech - the most critical part in a movie track - which become barely audible. This is what I want to overcome.
    Thanks,
    In fact I did not pay attention for this, but when I will try it next time , I will see and let you know...
    If there are many converters available, which one you thing is the best..
    Do you have an idea how to reduce the size of DTS files.. I tried surcode DTS encoder at 1536 Mb/s and 768 kb/s Both are giving me same file size... but if i rip the same files from DTS dvd, it give me half size.....
  18. Unregistered El Heggunte's Avatar
    IIRC, Surcode can output either to .dts or to .cpt, and .dts means "padded with zeroes for emulating a 2.0, 16-bit, 48kHz .WAV", whereas .cpt means "the real thing" (1509kbps OR 754kbps, respectively).
    Thanks for this information....
    I will try it..
    Regards
  1. Dts to ac3
    By vagos13 in forum Newbie / General discussions
    Last Post: 24th Mar 2012, 22:06
  2. Ac3 is indicated instead of dts - please help
    By Dr Forrester in forum Audio
    Last Post: 16th Feb 2010, 09:19
  3. Reauther dvd with pcm & dts to ac3 & dts
    By djblade in forum Authoring (DVD)
    Last Post: 16th Feb 2010, 08:40
  4. AC3 to DTS
    By Tolis1989 in forum Audio
    Last Post: 15th Nov 2008, 12:12
  5. DTS vs AC3
    By Mrsash in forum Newbie / General discussions
    Last Post: 29th Jul 2007, 10:16
