I have a DVD with only DTS sound and my DVD player cant play it.
I want to convert it from DTS to AC3 5.1 and then replace the original DTS one.
I know how to do evrything exept the convertion part, i have searched the forum and the internet and i cant get any tutorial that help me.
If anyone can point me to a simple tool that can handel this kind of convertion plaese help me
thanx alot in advance!!!
Results 1 to 30 of 79
Thread: DTS to AC3 5.1
Hi, try this guide - http://dtsguide.de.vu there's a link to the English version at the top of the page.
I tryed to follow this tutorial but i cant get any result is there another methood to do this?
Download
dts2ac3.zip
Requirements -
1) Avisynth
2) .Net 1.1 Runtime http://fileforum.betanews.com/detail...1/1016688677/2
Instructions
1) Unzip dts2ac3.zip
2) Rename your dts file to INPUT.DTS . Place in same folder as Dts2ac3
It will look like this
aften.exe
BePipe.exe
DTS.avs
DTS2AC3.bat
INPUT.DTS
libaften.dll
NicAudio.dll
3) Double click on Dts2ac3.bat . AC3 file will be named OUTPUT.AC3
That's it! Just make sure you install Avisynth and have .Net 1.1 runtimes installed
Your methood is graet and work but not compleatly
My DTS file is 791MB , 2:33:11 long but the AC3 output is only 62MB and 18:54 long
I did evrything that you told me is there anything else?
DVD with DTS only is illegal. DVD MUST have either PCM or AC3 audio in addition to DTS. The only DVD I've ever seen like this is that I have the Hong Kong DVD of Jackie Chan's _The Myth_ and the soundtrack is only available in DTS but it has an AC3 track of movie commentary by Jackie and some others. I think this film was also released in a cheaper version without DTS. That's the only film I've ever seen that doesn't have a true AC3 or PCM film soundtrack, but the AC3 commentary satisfies the requirements of not having only DTS on the disc.
I'm guessing that what happened is that you downloaded a Divx/Xvid file with DTS only sound and converted it to DVD. If the method above doesn't work, you'll have to either find another download with AC3 sound or buy a copy of the DVD with AC3 sound. I got tired of not being able to play DTS tracks, so I finally just bought a receiver that could play DTS and life is good. You could also consider buying a new DVD player that supports DTS as some do have DTS decoders. When you download files, there are no guarantees that you'll be able to play them without problems and as they say, you get what you pay for.
so there is no way to convert DTS to AC3 even if its STERO insead of 5.1?
http://forum.videohelp.com/viewtopic.php?t=320614
Unzip file below. Make sure your dts file is named Input.dts
dt2wav2ac3.zip
Double click on Dts_proc.bat to create a multichannel WAV, then convert to AC3 in app below
Originally Posted by Soopafresh
My resulting output.ac3 file won't get any bigger than 228,514KB, my input.dts is 1,071,613KB.
I've tried 5 times, always the same result...What am I doing wrong?
Thanks!
Have you tried my tool? DAudioK
I haven't personally test it... don't have any DTS sample at this moment... but please give it a try.
As soon as I can, I'll make some tests myself.My oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => http://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com
hi Rockas.
i too am trying to convert DTS to AC3. i tried dts2ac3 and the output was also not complete.
i then tried your program, but i get this error:
Run-time Error '6':
Overflow
i have the dts file, opened it with DAudioK, set output to ac3, selected 6ch, 48000 and 448kbps.
Can you cut a little chunk of the DTS file and send it to daudiok_at_gmail.com (_at_ = @)?
Currently i don't have a DTS file to run any tests
If you can't, tell me... I will search my DVD collection for a sample.
Thank youMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
Ok... sorry... just found a DTS track to run some tests...
I'll do them tonight
and Maybe release a version that supports them correctly.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
Rockas - (props to BJ_M) http://www.kellyindustries.com/sound...#dts_downloads
EDIT - Nevermind - They're DTS converted to MC WAVs
Thank you, anyway.
I will release in a few minutes a new version that shall be able to transcote DTS to all the other output formats supported by DAudioK.
30 to 45 minutes is shall be out.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
Thank you Rockas.
your work is greatly appreciated.
thank you
new release is out... please check my site and as usuall, comments are welcome on the tools section:
and feed back on the forum thread:
thank you, again.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
Hi Rockas,
the new version worked, however, the channels seem to be crossed, as the voice seems to be coming from the right speaker. this may just be my source and maybe it was poorly done. but i will e-mail you a sample shortly. since the file is too large to e-mail, i will upload it to a file sharing site and it will give you a link to download. it is not TOO big, so don't worry (~15mb).
again, your work is greatly appreciated.
edit: sent.
I got it... thank you.
I also sent you a little sample for you to test.
It's from a good source that way we may be certain about it.
I sent you that sample 'cause at the moment I can't test it, I'm away from home... that way I can continue working if you don't mind to run that test
thank youMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
I've tried your latest beta to convert an dts file to ac3, but I still get the overflow error.
Jaybeam - Welcome to the forums. As a general rule we discourage people from digging up old posts and adding to them. Don't make a habit of this, but I would say that in this particular case it was not totally wrong to do so. However, a new post would also have been OK.
Please note that some of our members do not bother to check threads after they contribute to them. They move on to new subjects. Rockas hasn't posted here since September of last year and he may not visit the forums any more. I suggest that you send him a private message or try to reach him via his website.
Hi everybody.
I'd read many topics on this forum and i never suceed that operation (DTS to AC3).
I've tried DKaudio, dts2ac3, besweetGUI, MeGUI ... and nothing of those software gave me a result.
With MeGUI i've got an error in the DirectShow filter.
With DKaudio the DTS import give a windows error which close the program.
dts2ac3 realize a 800ko file (but with an another file i suceed) ...
I've installed ffmpeg, avisynth ...
So Can you help me to convert my DTS file ?
eac3to , or foobar 2000 with dts plugin
You should also give a try to the "difficult" way: Avisynth ++ SoundOut plugin
( http://forum.doom9.org/showthread.php?t=120025 )
Good-luck!
I've tried with EAC3toGUI and it worked !
It's the graphic interface for EAC3toGUI and it's very simple.
Thanks a lot for help.
Simple it is, but I get an error when trying to convert a DTS file to AC3.Originally Posted by playj
It says that number of file, directory or volume label is not valid. What did you use?
@carlmart - follow the steps and the screenshots in this post, but for step 6, select "ac3" instead of "wavs"
http://forum.videohelp.com/topic363308.html
Thanks. It worked like a charm.Originally Posted by poisondeathray
Do you know of a good way to increase levels in the AC3 files, but having some sort of level indicator so as not clip anything?
Thinking again it might be better to do that on the dts file, which has higher bit count and should be less lossy, don't you think? Any way to check and change levels on a DTS file?
You can't do it to the dts file, unless you re-encode to dts with surcode. So the normal procedure would be to adjust it upon encoding to ac3Originally Posted by carlmart
You can use avisynth and normalize() which amplifies to 100% without clipping (max peak). I don't know the corresponding option in eac3to - I don't think it can
BeHappy and MeGUI (based on BeHappy) are avisynth based encoders and will do this dts=>5.1AC3 conversion with the option to normalize
If you use MeGUI, you don't even have to learn avisynth to do this, just set the program paths, and enter the .dts directly into the audio section and configure the options (i.e. normalize%, bitrate, etc....) it will automatically script the nicdts() input source filter for you
Another difference is eac3to will remove the dialog normalization by default (you can disable it), the other method does not. Usually dialog norm removal is sufficient (test it out for yourself)
For pc playback, you can adjust the ac3gain in ac3filter
My friend, I have done this last week for the dvd of LOST WORLD which had 5.1 DTS track and I wanted 5.1 Dolby track. The steps I used are as follows.
Extract the 5.1 DTS track from dvd by using " DVD AUDIO EXTRACTOR". You will have to buy this programe. This will give you option to extract 5.1 DTS to 6 mono wav files.
Open these files in Sony vegas. Check the configuration as the extracted audio does not specify the FL OR LFE channels. That you will have to find out. Then configure thro' vegas . Apply suitable gain or you will feel volume too low.
Render as 5.1 ac3.
Open Tmpgenc and open mpg tools. Here you can mux the new file with your original mpg2 video
or
Open Tmpgenc dvd author and open new project. Open video mpg2 and in place of audio select the newly made audio ac3 file and you can burn the new dvd. Chech for audio mismatch with video as I had a mismatch of 3 sec though I have processed everything in NTSC format. Now I am struggling to correct that as it starts prfect but misses the sync somewhere in between.
Kindly let me know the result.
Ac3 is indicated instead of dts - please help
By Dr Forrester in forum AudioReplies: 4Last Post: 16th Feb 2010, 10:19 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 09:40 -
AC3 Filter using SPDIF. No AC3 or DTS in WMP or MCE
By amadeus00 in forum AudioReplies: 2Last Post: 11th Dec 2006, 04:03 -
ac3 5.1 or dts 5.1
By cthulhu in forum Newbie / General discussionsReplies: 3Last Post: 18th Sep 2004, 18:07 -
DTS to AC3 ????
By joedef in forum AudioReplies: 2Last Post: 12th Jun 2004, 20:20
