VideoHelp.com Forum
    hi. I have recently used AutoGK to rip a movie into an AVI file with the XVID codec. I am trying to use SUPER video converter to convert the file into 3gp or 3g2 or mpg4 but they do not work.
    The SUPER video converter just shows the output status as Decoding Input when trying to convert
    to 3g2 with output codec at mpeg4.
    The SUPER video converter shows the output status as a small amount of kb when trying to convert to 3g2 with output codec at XVID. The file in the output folder is also only ~100 kb.
    I think the problem is the xvid codec. Is there a way i can change the codec in the avi file?
    Thanks.
    SUPER would use ffmpeg for 3gp output right? If so then libavcodec gets usd for all MPEG-4 decoding (Xvid, DivX, whatever).
    i don't see a libavcodec anywhere on super
    libavcodec is what ffmpeg (and mencoder) use for a majority of decoding. ffmpeg is basically made up of libavcodec (encoding/decoding) and libavformat (muxing and demuxing).
    Unless you have direct show enabled? In which case I guess it creates an AVISynth with directshowsource() to feed to ffmpeg/mencoder.
    well super will convert the avi files now. i just installed divx player and codec and restarted the comp. then there was no error.
  1. Converting 3gp file to WMV or AVI without losing clarity
    By brketch in forum Newbie / General discussions
    Last Post: 18th May 2011, 07:01
  2. Converting AVI (DivX/XviD) to MP4/MOV/3GP...
    By JaleAlbatros in forum Video Conversion
    Last Post: 23rd Jul 2009, 17:51
  3. Converting 3gp to MPEG4 .AVI
    By vworley in forum ffmpegX general discussion
    Last Post: 2nd Apr 2008, 12:48
  4. problems converting video with 3GP (error log included)
    By Luke Vader in forum DVD Ripping
    Last Post: 17th Dec 2007, 16:20
  5. problems converting to 3gp
    By swedishlf in forum Linux
    Last Post: 5th Sep 2007, 03:35
