    Dear All,,
    i have just purchased nokia 9500 communicator and intend to watch dvd movies on it...i have smartmovie 3.32 installed.it doesnot directly convert vob to avi...however when i try to route dvd files thru LATHE and then convert thru smartm..there is aparent jerkiness in movies,,though picture quality/sound quality is superb,,,...so my question is how to convert dvd files to avi format for further conversion...also please not that i want movies FULLLSCREEN I.E 640X200 as 400x200 cover half screen only...
    thanx and regards
    I have nokia 7710 that is also Series 90 phone and also using smartmovie and convert using this codec http://www.koepi.org/XviD-1.1.0-30122005.exe and the quality is just fine at fullscreen.
  1. video conversion/play on smartphone nokia
    By wijdbeens in forum Video Conversion
    Last Post: 25th Jun 2005, 20:25
  2. Nokia 6600 - DVD rip & Conversion ?
    By kv5 in forum Video Conversion
    Last Post: 14th Mar 2004, 13:00
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
