Hey all
I used DVD decrypter to rip the dvd to one VOB using the IFO function. I then tried using FairUse and AutoGK but im not geting any audio on my pc.
but when i burnt it to a dvd.. you could hear the track but there was loads of fuzzy crap over the top so its really painful to listen to.
whats going on? what can i do?
thanks for help
peace out
Ed
Results 1 to 14 of 14
Hi,
first copy the dvd to your hard drive.
Copy the the following notes in notepad and save like MERGE.BAT
Take all the vobs from the dvd, this is only an example.
Run the BAT program in the folder where the vobs are.
You have now 1 VOB called MERGE.VOB
Open this ALL.VOB in VideoRedoo and make a quickstream fix,sellect audio to mpeg,(dvd is ac3) you will see the video-audio synchr. is perfect.
Peter,Belgium (sorry for my engl.)
@ECHO off
copy VTS_01_1.vob /B + VTS_02_1.vob /B MERGE.VOB
EXIT
Hmm im a bit confused
Which bit do i copy into a notepad and save as .BAT?
However as you only have one VOB, I'm not sure what, if any, use this will be.@ECHO off
EXIT
Open the VOB in the latest g-spot (now 2.70) and have a look at the content. It might help to know what audio your source has. Also, what settings are you using in AutoGK for the audio ?
I think its a MPEG actually... I ripped with dvd decrypter as a NFO. Seems to be a MPEG...
that file plays fine on my pc. But when i try to just take a 30 sec clip out of it using VideoReDo it just ends up with no sound on the pc and if i burn to a dvd the sound is all fuzzy and horrible on my tv
Download
http://jsoto.posunplugged.com/tools/CutFile_exe.zip
Upload the output file to
http://www.bestsharing.com
the major problem is not just converting.. it that i want to get a 50 sec clip out of that mpeg... when i have tried to do that i end up with no sound or shit sound - my dvd has fine quality sound
Something has to be going on. Give us a small clip for analysis
ya its uploading.
Kewl...
Yeah, weird. Mpg2Cut2 allows you to demux it. The AC3 is very low in volume.
For a test, copy a VOB into the same folder as the script below and run fix.bat
The resulting .MPG file should be louder.
http://www.bestsharing.com/files/KDv...-norm.rar.html
p.avi
Sound lost after conversion mpeg to avi
By maclinux in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 13:47 -
avi to mpeg -> no more sound
By myk in forum Video ConversionReplies: 22Last Post: 14th Mar 2008, 12:15 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 00:49 -
MPEG-1 to AVI DivX: No sound
By Waterman II in forum MacReplies: 0Last Post: 18th Sep 2007, 03:16 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21
