VideoHelp.com Forum
    Hi, I'm having problems playing back Divx movies on my 3455H player.
    -I have burned a DVD with some divx movies on it and when I put it into the player, the player will read the disc and show the names of the movies available, but will not play them and come up weith a message "video file not supported".
    I think im doing something wrong in the burning process, but I have no idea what it is. Can someone piont me in the right direction with what i should do? ie. what codecs/burning software should i use?
    This site is about the Philips DVP-642 but much of the information there applies to other Divx/DVD players:
    http://www.jarnot.com/twiki/bin/view...LisaBsAVIGuide
    If you are using Nero Burning ROM use the DVD-ROM (ISO) template. Keep your files under 2GB each. The fact that the player displayed the names of the files probably indicates you burned the disks properly. There's probably something about the files that it didn't like.
  1. Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
    By Roberht in forum DVD & Blu-ray Recorders
    Last Post: 11th Feb 2012, 12:37
  2. I fixed my Philips DVDR 3455H dvd/hdd recorder
    By dphirschler in forum DVD & Blu-ray Recorders
    Last Post: 26th Feb 2011, 18:40
  3. Philips DVDR 3455H and DishNetwork DVR 625
    By mdtx001 in forum DVD & Blu-ray Recorders
    Last Post: 14th Oct 2010, 17:57
  4. philips dvdr 3455h
    By mikes94547 in forum DVD & Blu-ray Recorders
    Last Post: 24th Dec 2008, 09:36
  5. Philips DVD 160GB Recorder Model DVDR 3455H
    By vsenapati in forum DVD & Blu-ray Recorders
    Last Post: 28th Jun 2007, 19:56
