Hi agian guys.
Just a quick question. I have been looking around a bit to see if I can remove hardcoded subtitles from an avi file.(My subtitles were out of sync) Is there a program that can remove them completly, or would it just be easier to re-encode the dvd? (I started re-encoding already, but was just curious(takes about 3-4 hours for re-encode, wanted to watch the film right now).
- I'm pretty sure re-encoding is the way to go then Subsync them but just want to make sure.
The image behind the subs is gone. You will get much better results by re-encoding than you ever would trying to remove them. Aside from the fact that removing them would involve re-encoding anyway.
Hardcoded Subtitles
By Bruno AUgusto in forum EditingReplies: 4Last Post: 7th Apr 2012, 13:29 -
How to add hardcoded subtitles to WMV using ffmpegX
By Vitoarc in forum ffmpegX general discussionReplies: 0Last Post: 12th Mar 2010, 11:42 -
How do I Redo Subtitles of TV series on DVD and delete dubbing
By killinmesmalls in forum SubtitleReplies: 8Last Post: 21st Jan 2010, 13:34 -
MKV to avi with hardcoded subtitles + opaque box
By Markomaani in forum SubtitleReplies: 3Last Post: 19th Mar 2009, 11:42 -
Extracting hardcoded subtitles-does anything actually work?
By kpic in forum SubtitleReplies: 3Last Post: 2nd Jun 2007, 06:34
Statistics
Newest guides
Latest tool updates
New media comments
