VideoHelp.com Forum
Results 1 to 9 of 9
    Hi
    i seem to have a problem encoding a dvd with mpeg2enc preset on version 0.0.9x r2.
    it doesn't complete the whole dvd movie even thoug it finishes the encoding process; it creates a m2v file a mpeg file an an ac3 file. The m2v file 140 kb long and the mpg file like 647 mb long
    the audio is intact but the movie shows a black screen
    I had problems, too. - see http://forum.videohelp.com/viewtopic...673656#1673656
    good luck!!!
    Hello. i used the ffmpeg preset encoding the dvd and works like a charm!
    Also tried Visual Hub and had no problems
    I also have problems with mpeg2enc. ffmpeg does not give you control over subtitle location. Visualhub does not handle subtitles at all.
    You need the mpeg2enc binary from the older .9s version. That will permit you to alter the font, size, and placement of the subtitles.
    PM me if you can't find the older binary and I'll eMail it to you.
    I have some problems with the download of the mpeg2enc.
    When I download it, it is just a .txt file. I don't think it is correct. And after downloadinf it where do I have to put it?
    Thank you for your help!
    Just remove any extension from the file name. ffmpegX will ask for it when you launch the app so just tell it where you put it (your Desktop, for example), provide your password, and let it install it in the correct location.
    If you're talking about the older mpeg2enc binary (and the current one is already installed), go to Library/Application Support/ffmpegx, create a new folder in there called "mpeg2enc(new)", drop the existing binary in there, and then drop the ".9s" binary in its place. Also make a new folder called "mpeg2enc(9s)" so you may swap the old binary out and the new one in as you wish.
    Thank you a lot! ^_____^ It works!
    By the way, if ffmpegX complains about the older version of the mpeg2enc codec (but you want to use it), just ignore the complaint. It will work. When you swap the codecs back, the complaining will stop.
  1. MPEG2Enc encoding from VirtualDub
    By Computer Nerd Kev in forum Capturing
    Last Post: 19th Jul 2011, 07:38
  2. Avi to DVD (mpeg2enc), doesn't fit screen (noob)
    By bilboshaggins in forum ffmpegX general discussion
    Last Post: 14th Dec 2008, 14:53
  3. Crash in 0.0.9y converting AVI to DVD using mpeg2enc profile
    By mainframer in forum ffmpegX bugs and suggestions
    Last Post: 20th May 2008, 01:05
  4. Replies: 15
    Last Post: 14th Apr 2008, 09:23
  5. Problems w/selectable subs avi-DVD w/mpeg2enc
    By kenzo69 in forum ffmpegX general discussion
    Last Post: 20th May 2007, 05:53
