VideoHelp.com Forum
    1) How do you convert PAL mpv to NTSC mpv? (yes mpv not wmv)
    I also have the accompanying mpa file, do I have to do anything with that?
    2) How do you change 4:3 to 16:9? what software to use and how?
    (guide somewhere?)
    Thanks.
    1. You get a dvd player that can output PAL to NTSC.
    2. You don't as you have to crop and then zoom.
    And please search http://www.google.com/search?hl=en&i...=videohelp.com
    How about muxing them mpv and mpa back to mpg or avi... what kind of tool do I need? I'll search, I'll search... I just so new don't even know what to search.
    Muxer? Encoder?
    Thanks.
    Hi ssalim
    I use TMPGEnc Xpress and DGpulldown to convert PAL to NTSC.
    http://www.videohelp.com/tools?tool=DGPulldown
    It works fine.
    Input audio and PAL video to TMPG, otput as Audio and video separate in PAL only change size to 720x480.
    Than DGpull change framerate of video from 25 to 29.97
    Than you can use any editind software to make menus or just TMPG to export DVD NTSC complient file and burn.
  5. The Old One SatStorm's Avatar
    TMPGenc 2.5 free, has an option called "mpeg tools". You can mux them using this.
    Another option is bbmpeg.
  1. x64, mpv, etc HD video to DVD9?
    By MaTTuP in forum Authoring (DVD)
    Last Post: 29th Oct 2009, 08:23
  2. MPV crashing
    By SignedupGuest in forum Newbie / General discussions
    Last Post: 24th Aug 2009, 15:38
  3. AVI -> DVD but no .MPV?
    By Kiona in forum ffmpegX general discussion
    Last Post: 3rd Dec 2008, 07:53
  4. How to play MPV?
    By GangstaRap in forum Newbie / General discussions
    Last Post: 1st Dec 2007, 15:18
  5. mpg4/mpv to avi ....No Video
    By trueman in forum Video Conversion
    Last Post: 24th Jul 2007, 09:40
