VideoHelp.com Forum
  1. Hi! i have copied some home movie footage onto my pc using shrink to crop and pick out the best bits but the problem is the transition between each scene pauses so what programme will open VTS files so i can add transitions, the programme needs to be simple to use as i am new to this editing thing.
    Not many editors supports dvd vobs directly. But you can try mpeg video wizard...not the easiest tool though. Or convert the dvd vob to one mpeg with vob2mpg and try Windows Movie Maker.
  3. I've managed to edit it with windows movie maker with good results but it does'nt let you burn to DVD only CD is there a programme that will let be burn my windows movie maker projects to DVD.
  4. Member mats.hogberg's Avatar
    Save as DV video from WMM.
    Encode to DVD mpg with your fav mpeg2 encoder (see tools left for suggestions - hcenc for a good free alternative)
    Author as DVD with your fav DVD authoring app (see tools left for suggestions - TDA for example)
    /Mats
    Mpeg video wizard cool thing. It works with VOB's. You can edit them (cut, Transitions, etc).
    Try it.
  1. Programme picking help
    By zinc in forum Authoring (DVD)
    Last Post: 14th Nov 2009, 07:09
  2. How to check what authoring programme was used?
    By grzegorz in forum Authoring (DVD)
    Last Post: 4th Dec 2008, 01:26
  3. converter programme
    By VaGaBoNd in forum Video Conversion
    Last Post: 27th Feb 2008, 04:33
  4. Programme won't install
    By DuBsTaR in forum Computer
    Last Post: 18th Nov 2007, 09:06
  5. good editing programme
    By leegutcher in forum Newbie / General discussions
    Last Post: 22nd Jul 2007, 07:28
