I'm currently ripping and encoding on an Athlon 1400 512MB DDR RAM on Windows 98SE.
Would I see a vast improvement if I upgraded to an Athlon XP 1700 and installed Windows XP Pro.
Would I need the latest Version of TEMPEnc to use XP?
Thread: Is it worth Upgrading CPU and OS
yes you would see some improvemens from speed if you upgradeuor CPU but why in the blue moon would you upgrade to XP.....XP is just to much work for one person to activate and when your going to put new hardware on your PC you have to call them and activate it again....so i suggest you get Win2000 or stick with Win98
Upgrading wireless card. Worth it?
By vipertongn in forum ComputerReplies: 5Last Post: 13th May 2010, 18:25 -
Need Advice on Upgrading CPU
By AuroEdge in forum ComputerReplies: 19Last Post: 26th Oct 2009, 01:22 -
Thinking of upgrading AMD CPU which ones are possible with my PC?
By Denvers Dawgs in forum ComputerReplies: 11Last Post: 22nd Dec 2008, 10:23 -
Upgrading M/B & CPU, no other existing hardware, likely problems ???
By blinky88 in forum ComputerReplies: 5Last Post: 15th Aug 2008, 15:02 -
upgrading CPU on Dell Optiplex 745... do-able??
By Webster in forum ComputerReplies: 2Last Post: 28th Sep 2007, 15:16
Statistics
Newest guides
Latest tool updates
New media comments
