I've just got a dvd player which supports divx format ... so i want to know how
can i burn subtitles to avi files then burn it on cd or dvd (can i burn it to a dvd , or do i have to convert it first ?) !
do i need a certain format of subtitles (eg, srt) ?
Wrong link, I mean http://forum.videohelp.com/viewtopic...ght=srt+player
thx, precisely what i wanted .. gonna try it
using sub2divx do i have to compress the avi again to add the subtitle ? coz i tryed virtualdub and i needed to compress the file to burn the subtitle .
thnx again
Most DVD/MPEG-4 players support and can play external subs for AVIs in a variety of formats, SRT being the most common. If your player manual doesn't tell you which it supports, maybe check the DVD player database at this site.
To "burn" or "embed" your subtitles into the AVI requires reencoding (recompressing), something you'll want to avoid if possible.
Burning movies with subtitles?
By legenderycity in forum Authoring (DVD)Replies: 9Last Post: 29th Jan 2010, 08:32 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Problem: LG HT302SD Home Theater does not show VobSub subtitles.. plz help
By eng_asa in forum SubtitleReplies: 2Last Post: 8th Oct 2008, 01:41 -
Subtitles and codecs for burning
By vipertongn in forum SubtitleReplies: 0Last Post: 17th Aug 2007, 17:23 -
Audio Cd Burning (Nero 7 Ultra Edition) NIGGLE... plz help!
By mceyedol in forum AudioReplies: 2Last Post: 30th May 2007, 14:30
