I have tried for 2 days to get any kind of burned blu ray video to play on my PS3 and nothing works.
Has anyone been successful at this?
Im trying with a BD-RE disc.
I have tried lots of authoring software.
I tried rip/decrypt/burn talladega nights movie.
No matter what the PS3 refuses to play it.
Always the disc is detected as a BD-RE by the ps3 and when i play it i get error 80029941.
Discs play properly on the PC.
I could not even find the proper burn settings anyware
Like what UDF version to use?
I tried burn with authoring software "DVDIt Pro HD" and it doesnt play.
So i have 2 questions.
1. Has anyone gotten any sort of burned blu-ray disc to play on the PS3?
2. Is there instructions somewhere on how to properly author a bluray disc so it plays on ps3.
Thanks.
Thread: Blu-ray authoring help
Eric
I hope I'm not sounding condescending...
1st-Is your material proper resolution, codec, etc for Blu-Ray?
2nd-Are you using authoring software that actually supports authoring to the Blu-Ray spec?
3rd-What burning software are you using? Does it support burning Blu-Ray?
4th-Does the PS3 explicitly say that it'll support BD-RE playback?
Both BD and HDDVD use the UDF v2.5 filesystem. I'm assuming you're creating an HDMV-formatted title, not BD-J...
Tell us what you've tried...
Authoring Blu Ray in Encore
By Vasilis in forum Authoring (Blu-ray)Replies: 6Last Post: 19th Nov 2011, 12:44 -
3D Blu Ray authoring
By Shilar in forum Authoring (Blu-ray)Replies: 10Last Post: 8th Apr 2011, 22:28 -
Authoring Blu-Ray
By whoisquilty in forum MacReplies: 3Last Post: 13th Aug 2010, 10:57 -
Blu-ray Encoding and Authoring Help!!!
By jbandy1 in forum Authoring (Blu-ray)Replies: 7Last Post: 7th Aug 2010, 11:32 -
Blu-Ray authoring - why all the complaints?
By lordsmurf in forum Authoring (DVD)Replies: 6Last Post: 18th Feb 2008, 20:17
Statistics
Newest guides
Latest tool updates
New media comments
