VideoHelp.com Forum
  1. Hi,
    I am getting into using the .mkv container for archiving my movies. It is flexible enough that I can go back and add audio files or swap subtitles etc...even add DVD chapter info to a DvX file, it is really amazing.
    The only problem I am having is finding a DVD Chapter extractor for Mac. At the moment I have to unfortunately use parallels and use a Windows program called ChapterXtractor at http://www.digital-digest.com/softwa...8&ssid=0&did=1
    Is there a Mac version or something that does the same job?
    Creating .mkv files is slightly fiddly going through a few different apps but the end results are amazing. I don;t see it talked about enough really but here is a guide I am following for it: http://homepage.mac.com/janlitzinger...CreateMkvs.zip
    Cheers
  3. Member cincyreds's Avatar
    mkvtoolnix (mkvextract) does not extract chapter info directly from DVDs (IFO files). It will extract chapter info from MKV files though, but the chapter extraction feature is only barely implemented and not too flexible.
    dvdxchap inside ogmtools
    For mac: ogmtools.darwinports.com
  1. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 2nd Mar 2012, 15:25
  2. Replies: 19
    Last Post: 3rd Jan 2012, 16:05
  3. MKV stream extraction causing audio sync problems
    By PlanetIndigo in forum Video Conversion
    Last Post: 29th May 2011, 22:07
  4. MKV chapter file extraction problems
    By ikarishinji41 in forum Editing
    Last Post: 22nd Mar 2010, 11:03
  5. VOB2MPG Chapter Extraction Problem
    By murray666 in forum SVCD2DVD & VOB2MPG
    Last Post: 20th Oct 2009, 03:14
