The model is samsung dvd-p365 and I can't play divx movies that are 23fps... the image gets distorted and it loads about 40secs when I insert a disc with a 23fps movie. Those with 25fps work like a charm. Is it probably because it is locked on region 2 or what??
Thread: samsung dvd player divx problem
Nope, no regions on divx cds/dvds.
Can you play NTSC(often region 1) dvds without problem?
Can you provide a sample so i can test?? Although i don't use ntsc.. i am from europe and my tv and dvd are set on pal...
doesn't anyone have any ideeas.. nobody has a dvdplayer like mine??
then you can create one using Nero Vision for example...Originally Posted by boditza
download any trailer > make NTSC DVD > burn > test
Samsung P-191 DVD player Firmware problem
By stfly in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Jun 2010, 09:17 -
Samsung dvd-4155 DVD Player/recorder format problem
By jamesd1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th May 2009, 22:51 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41
