in powerdvd, i can play xvid/divx through installing those codecs, but I cannot seem to play any RMVB eventhough I installed real's codecs.
anyone know how i can play it in powerdvd? reason why i want to play it in powerdvd beacuse i like powerdvd's playback x2 feature. no other players has this
but if you know of a filter/AVS script for MPC, or anohter player that can paly RMVB and allows playback speed to be at X2, please share.
thanks!
Did you install Gabest's realmedia splitter? That together with real's decoders should allow playback in any dshow based player.
MPC should be able to play it back 2x speed though. mplayer also, but it doesn't keep the pitch (don't know if powerdvd does).
As for AVISynth, there is the TimeStretch function, which can preserve pitch.
yes i have that RM splitter installed. maybe.. powerdvd isnt a DShow player? Though i'm pretty sure i was able to use FFDshow with powerdvd. Or it isnt using that particular splitter somehow? Can i force powerdvd to use it?
Yes, MPC can play at 2x, but like u said doesnt keep ptich. Powerdvd does.
Thanks i'll try to experiment with Timestretch
PowerDVD won´t play it !
By JGT in forum Blu-ray RippingReplies: 9Last Post: 3rd Feb 2010, 15:37 -
AVCHD M2TS playback problem in PowerDVD
By prizi in forum Software PlayingReplies: 2Last Post: 4th Apr 2009, 07:18 -
Sudden playback problems in VLC and PowerDVD
By ecc in forum Software PlayingReplies: 7Last Post: 30th Jan 2009, 21:33 -
PowerDVD 6.5 HD playback
By wulf109 in forum Software PlayingReplies: 1Last Post: 22nd Jan 2009, 07:05 -
PowerDVD playback problems Plz help
By ian curtis in forum Software PlayingReplies: 8Last Post: 25th Oct 2007, 03:40
Statistics
Newest guides
Latest tool updates
New media comments
