I use MTR 2.6.6 to rip movies...
usually I have no problems...
Open Season & Saw 3 both returned the following errors...
READ ERROR: Can't Open IFO.
I/O ERROR: Can't Read DVD File Structure.
I click OK and thats as far as it goes.
When I open the VIDEO_TS folder there are 328 in there.
Is there a way around this?[/u]
Results 1 to 17 of 17
1) Disable pre-scan in preferences.
2) MTR Title Set Extraction Main Feature- Make sure you choose Title with (MF) behind it.
3) Ignore error message.
4) Let it rip.
5) Ripped Video_TS won't play with DVD Player
6) Use DVD2oneX Movie Only to take out Empty Cells.
7) Burn to DVD
You could go to RipDifferent and join the MTR forum to read all about how to succeed in ripping your DVDs.
Cheers Lawnman
worked a treat. I also signed up as you suggested. top man!
I've been trying to do this for many times. And when i'm ripping it stays in 526MB and stays there. altough I can hear the dvd slot working... is this normal?
Just let it rip.
Quick question. Empty cells are the ones with 0 mb or 0 sec? I've got some with 0mb and like 1 sec then some with 2 sec and 0mb.
as long as they are in a grouping, then you want to delete these.
if they are preceeded and followed by files that are
more than 1 sec, andmore than 0mb, then these would be layer break files, and you do not want to delete those.
just only delete the ones that run like this example:
1 1sec 0mb
2 1sec 0mb
3 1sec 0mb
4 1sec 0mb
5 1sec 0mb
30 1sec 0mb
31 1sec 0mb
32 1sec 0mb
where the first 32 cells (1-32) are 1 sec long and 0mb in size."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
terryj
I think I understand what you are saying...however, I have come across a case (Open Season) where there are cells with 0:00 in length and MORE than 1mb in size. They are in successive order with the ones that are 0mb, so I 'm not sure if they should be deleted. Is there a rule about this?
Thank you so much your help.
Yes they should be unchecked.
If you look at Chapter column take out the zero cells till you see chapters run in order, 1,2,3,4 etc. Notice right now that they are all chapter 1.
Thank you very much. That worked great for Open Season. Unfortunately, not so for Running with Scissors and U.S. vs. John Lennon.
I did this with MTR 2.6.6 and it worked for me. Just let it rip when it seems to stop.
Do title set extraction (pre-scan disabled)with MTR 2.6.6
Make sure you choose Title#(MF).
Let it RIP!
Then do movie only with DTOX (Empty or zero cells)
Use this method on both. It worked on both for me and fellow members at RipDifferent.
I understand everything so far - but it seems that DVD2OneX2 won't recognize my burner......?
When i go to burn it says:
"The selected Drive is not capable of burning DVD media."
I have an external I/o Magic DVD burner - and it's worked fine with every other program that I've attempted to use it with... is there a way to save the movie with the newly deleted empty cells and take that into Toast and burn? or a way for DVD2OneX2 to recognize that my burner is functional?? any suggestions?
thanks in advance
thanks for the help socks - got it goin now
I am having a problem copying Running with Scissors. It seems my DVD burner will not see the DVD. I've tried various rippers, DVD Fab Platinum, DVD Decrypter and various others. I take the disc to another pc and it plays on WinDVD, but after installing Win DVD on my pc it still will not see or play it. Is there some issue with my burner/player? I am using an NEC 3520AW burner, and it has always worked flawlessly. It is still working fine, but just not with this disc as well as a couple others here lately. Whats changed, and what do I need to do? Thanks.
Just a Hint, you are in a Mac forum asking about your windows problem.Originally Posted by weflyrc
Is there a media Player that can read .IFO file and play FLV files (Youtube
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 29th May 2011, 17:46 -
cant open wmv files. have read previous forums.
By UmmAddan in forum Newbie / General discussionsReplies: 9Last Post: 29th Dec 2009, 12:49 -
DVD Pro Lab - Error: Read Data Size
By lapetite_66 in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2009, 14:48 -
How to read/extract info from ifo file
By cd090580 in forum ProgrammingReplies: 6Last Post: 15th Feb 2009, 22:42 -
Disk read error....
By rubberman in forum ComputerReplies: 12Last Post: 12th Feb 2008, 14:06
