Hello, I have some .dts files I would like to burn as a DTS CD, what can I use to convert the .dts file to a dts encoded .wav file for burning to a DTS CD? I've downloaded dts encoded wav's before, and successfully burned them to cd as an audio cd, and played them in my Home Theater, but I don't know how to transcode the actual .dts file. Oh, and is there a way to go the other way around too? To transcode the .wav to a .dts file? Thanks!
-capT
I haven't lost my mind; I have a tape back-up somewhere. ~Author Unknown
Back up my hard drive? How do I put it in reverse? ~Author Unknown
Surcode will encode wav source to DTS for either CD or DVD.
Where did the .dts files come from ?
If they came from DVD source then they will have to be re-encoded, as DVD DTS is 48kHz, CD DTS is 44.1Khz.
Ooooh...
Yes, the .dts files are indeed pulled from a DVD. So I would have to separate them into the 6 separate wav files, and then re-encode them to 44.1kHz and then use Surcode to create the dts-wave. I think I looked at surcode once, and it is not free nor trial version, right? I guess I'll have to decide if I really want to do it at this point then. Thanks guys!
-capT
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 2Last Post: 17th Jan 2012, 00:48 -
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 12Last Post: 29th Jun 2011, 22:30 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
Statistics
Newest guides
Latest tool updates
New media comments
