My PVP will only playback asf.
Whats the best (and quickest) software to convert avi (divx or xvid) to asf ?
cheers
Results 1 to 30 of 39
Thread: AVI to asf ?
Anything else out there ?
Yes
I tried SUPER build 21, but it kept bringing up an error when converting to WM7 with WMA audio.
The same happend with WM8 and WMA.
The other asf settints for SUPER converted and played on the PC but not on the PVP.
I thought SUPER had all codecs built in, so why the errors ?
SunPlus PMP Transcoding
Or maybe MediaCoder.
Video
Backend > FFMPEG
Format > MPEG4 or MS-MPEG4-V2
Container > ASF
Audio
Encoder > FFMPEG
Audio Format > IMA Adaptive PCM
Or... VirtualDub with ASF Codec / MPEG-4 V1/2/3
and change container using FFmpeg
ffmpeg.exe -i test.avi -acodec copy -vcodec copy test.asf
Thanks, I'll give the above a try.
I just checked the video that this PmP will play with GSpot and got the following info:
FIle type: ASF (WMA/WMV)
mime type: video/x-ms-asf
the following combination of filters was used
VIDEO: (s) ffdshow MPEG-4 video decoder (R)
AUDIO: (S) ffdshow audio decoder (R)
Now all I need is a program to convert my Divx avi's to the exact asf file as above.
Thanks, thats a great tool.
Here's the info I need to duplicate:
video has been encoded in MS MPEG-4 V3 and 1 channel ADPCM.
Use MediaCoder.
-- Audio
- Source = Auto Select (MPlayer)
- Encoder = FFMPEG
- Downmix = Right or Left Channel
If You need use Resample, Gain, Normalize.
-- FFMPEG
- Audio Format = IMA Adaptive PCM
If You need - change Bitrate.
-- Video = Auto Select (MPlayer)
- Backend = FFMPEG
- Format = MPEG4
- Container = ASF
-- Picture
If You need - use Resize (example 320x240) and Frame Rate (default 25.000)
Transcode small sample and check on PVP.
If can't play - maybe use AsfBin to re-muxing ASF file.
Please, check more details - bitrate audio & video; width & height video; sample audio - and use some parameters in MediaCoder.Originally Posted by rindless
can't install the latest version of Mediacoder..comes up as error.
Installed the previous stable version, and used the settings you mentioned.....the program crashed every time, even with different type of avi's.
Does mediacoder come with all the required codecs built in or is my pc missing something ?
Hmm... MediaCoder never crashed on my computer.
What is Your operting system and CPU?
Check MediaCoder FAQ
maybe thats the problem (CPU).
I've found a program that works and it fast too:
Arcsoft MediaConverter.
The only down side is that the maximum video bitrate is 1.5Mbits.
This produces nice video but small compression artifacts are visible.
What I need now is a program that does what this software can do (without the need of a top spec pc), but be able to encode at a higher video bit rate.
I'm search, download and install old Windows Media Tools.
Recompress video file in VirtualDubMod.
Video > Full processing mode,
Compression... > Microsoft MPEG-4 Video Codec V3,
change Data Range (Kilobits per seconds) in Configure,
optionally - use resize filter and maybe Cropping... option,
Streams > Stream List,
right mouse button on audio stream > Full processing mode,
Conversion... > Channels = Mono,
optionally - change Sample rate and Precision,
Compression... > IMA ADPCM > choose format,
and Save As... to AVI.
From command line (cmd):
vidtoasf.exe -in name_file.avi -out name_file.asf -seekable on
(Windows Media Tools installed vidtoasf and other tools to /Windows folder.)
Optionally - use AsfBin to build index in ASF.
I've followed your instructions with virtualdubmod and created an avi with the correct codecs and settings and bit rate. The file plays great on the pc.
Just can't get it to load in to asfbin so it becomes an asf video file.
How do I do that ?
This is so fustrating because with your help i'm so close.
I've got the video encoded in the correct Microsoft MPEG-4 Video Codec V3.
The audio is also correct: IMA ADPCM
Why can't Virtualdubmod save as asf instead of avi ?
So all I need now is to keep everything the same except I need an asf file instead of avi.
ASFbin looks like it could do the job, but it will not load avi's ?
What should I do now ?
VirtualDubMod can save to AVI, OGM and MKV - not ASF/WMV.
AsfBin works with ASF/WMV (cut, join and re-mux).
Change container:
Or change container using FFmpeg:
Maybe not needed use AsfBin after change container - just check.
Other way... use shareware/trialware converter - example YASA Video Converter, SolveigMM ASF Multiplexer...
Just did some indepth checking and the video file must have 48KHz, 1 channel, ADPCM or it will not play on the PVP.
VirtualdubMod will not encode ADPCM above 44.1KHz.
Originally Posted by Placio74
First change Conversion... (Audio Conversion) settings - after choose Compression....
VDM change Sample rate and encode to ADPCM.
Check this file: http://www.speedyshare.com/892730227.html
"You don't know what you got, until you lose it".--John Lennon
Just downloaded your file and it plays great on the pc but will not play on the pvp.
I've done a side by side info comparison using media info and the only difference between your test asf file and the pvp file is:
pvp file= 1 video stream : MS MPEG-4 V3
test file= 1 video stream : S-MPEG 4 V3
(the audio is exactly the same for both files)
could the above video info be causing the problem ?
Check this - http://www.speedyshare.com/874401451.html
File is created in MediaCoder (FFmpeg) with MPEG-4 (MP4S) and re-muxing in AsfBin.
Before in VDM i'm used MS MPEG-4 V3 codec (MP43).
From MediaCoder console:
(Windows Media Encoder can encode video to ISO MPEG-4 (MP4S), but not use ADPCM audio (?).)Code:ffmpeg.exe -y -i Test1.avi -f asf -vcodec mpeg4 -me full -b 3000*1K -r 25 -s 320x240 -aspect 4:3 -acodec adpcm_ima_wav -ab 224 -ar 48000 -ac 1 Test1.asf
Hmm... show this error...Originally Posted by rindless
Your new (test1) video file will not play on the pc or PVP.
I checked the video properties with media info, and everything is exactly what I need.
Does this file play on your PC ?
Oops, sorry.
Yes - play, but with ffdshow.
Without ffdshow - not.
where do we go from here ?
If the program we find is damn good and it's payware, that's fine.
What's worth buying that will do the job ?
Maybe check Video Vault PVP...
Wat is Your PVP device?
If You have, maybe upload sample file?
hi, i have the same problem as u guys.
Recently got myself a PVP and using the Sunplus Transcoding Tool mentioned earlier. My main probs with the software is tat it cannot convert rmvb files directly n doesnt batch-encode. I can find a workaround for the first problem, but not being able to batch-encode files means i have to slowly convert file by file, which is madness. So i was hoping to find another tat does.
Anyway, I ran file encoded with the Sunplus proggy through MediaInfo, and tis was wat i came up with:
General #0
Complete name : G:\HC03.asf
Format : Windows Media
File size : 147 MiB
PlayTime : 22mn 39s
Bit rate : 908 Kbps
Video #0
Codec : DivX 4
Codec/Family : MPEG-4
Codec/Info : Project Mayo DivX 4
Bit rate : 511 Kbps
Width : 352 pixels
Height : 240 pixels
Aspect ratio : 1.467
Audio #0
Codec : ADPCM
Codec/Family : ADPCM
Codec/Info : Intel ADPCM
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48 KHz
I also tried Mediacoder to replicate this format, but i realised their options of 'MPEG4/MS-MPEG4-V2' is different from the DIVX4 codec found in Sunplus, and i'm guessing tis is the reason why our attempts all failed.
So it seems to me, tat we nid to have a file tat's encoded using DIVX4 (and not the newer divx versions), adpcm audio, in an ASF container. Any idea how we can do tat?
whazzup, please check this samples:
http://www.speedyshare.com/145999823.html
http://www.speedyshare.com/982147891.html
http://www.speedyshare.com/920827448.html
hey Placio74, speedyshare says my URL is not valid/blacklisted, so I cannot download any of the files, maybe can use yousendit?
a mixture of successes n failures so far...
First, found out that Sunplus actually has TWO versions of their transcoding tools, 0.4.1 and 0.5.1, and although video is still using DIVX4 for both, 0.4.1 uses ADPCM, while the newer 0.5.1 uses PCMS16LE. The 0.5.1 file is almost 2 times bigger than the 0.4.1, but quality is similar (EDIT: barring 1 exception mentioned below).
MEDIAINFO of a file encoded using 0.5.1:
General #0
Complete name : E:\Anime\[JZONE.53KD.COM][PV] (2007.02.21) SUEMITSU & THE SUEMITH - Allegro Cantabile (704x480 MPEG2)X.ASF
File size : 63.1 MiB
PlayTime : 4mn 17s
Bit rate : 2059 Kbps
Video #0
Codec : DivX 4
Bit rate : 509 Kbps
Width : 352 pixels
Height : 240 pixels
Audio #0
Codec : PCM
Codec/Family : PCM
Codec/Info : Microsoft PCM
Bit rate : 1536 Kbps
Then I found out that Arcsoft Mediaconverter CAN produce useable files, MEDIAINFO as below:
General #0
Complete name : C:\Documents and Settings\Administrator\Desktop\[JZONE.53KD.COM][PV] (2007.02.21) SUEMITSU & THE SUEMITH - Allegro Cantabile (704x480 MPEG2).asf
File size : 34.2 MiB
PlayTime : 4mn 16s
Bit rate : 1116 Kbps
Video #0
Codec : FFmpeg MPEG-4
Codec/Info : Microsoft MPEG-4 (hacked MS MPEG-4)
Bit rate : 918 Kbps
Width : 320 pixels
Height : 240 pixels
Aspect ratio : 4/3
Audio #0
Codec : ADPCM
Bit rate : 176 Kbps
Sampling rate : 44 KHz
HOWEVER, the audio has a static buzz, probably due to the ADPCM codec. And, after I chose ASF-MPEG4, I can only choose certain settings while some are greyed out...
AND, a pecularity of the ADPCM codec in Arcsoft's s/w is tat if i played a Arcsoft encoded file, then play a 0.4.1 encoded file, the static buzz will also be present in the latter. But If i play the 0.4.1 file upon starting the machine and dun go anywhere near the Arcsoft file, no buzz.
sigh, the search continues....
OK.Originally Posted by whazzup
http://www.yousendit.com/transfer.ph...C04DF5535B8DA4
Recompress in VirtualDubMod with DivX 5,
change FourCC in AVI FourCC Code Changer,
change container with vidtoasf.
Play OK with ffdshow, DivX 5, Xvid.
http://www.yousendit.com/transfer.ph...95CB6924721191
Recompress in VirtualDubMod with ffdshow VfW (Encoder MPEG-4, FourCC DIVX),
http://www.yousendit.com/transfer.ph...38A2F00E053859
Recompress in MediaCoder/FFmpeg - Backend FFMPEG, Format MPEG4, change FourCC ( add -vtag divx in Settings>Extra Options), Container ASF,
re-mux in AsfBin.
Black screen with DivX Decoder Filter (5.0.5) & Xvid Decoder Filter.
Play OK with ffdshow.
http://www.yousendit.com/transfer.ph...99190A5C025E36
Recompress in MediaCoder/FFmpeg - Backend FFMPEG, Format MPEG4, change FourCC ( add -vtag divx in Settings>Extra Options), Container AVI,
Play OK with ffdshow, DivX 5.
ASF to AVI
By Arizona42 in forum Video ConversionReplies: 1Last Post: 31st Aug 2008, 23:20 -
ASF to AVI
By Cyberian v2.0 in forum Video ConversionReplies: 5Last Post: 20th Jun 2004, 03:26 -
ASF to AVI
By deadman in forum Video ConversionReplies: 9Last Post: 3rd Sep 2002, 17:31 -
.avi to .asf????
By Kleuter in forum Video ConversionReplies: 4Last Post: 15th Oct 2001, 22:20 -
NEW SITE FOR MPEG TO ASF or AVI TO ASF
By Goldenaxe4000 in forum Video ConversionReplies: 0Last Post: 30th Aug 2001, 01:15
Newest guidesLatest tool updatesNew media commentsRecent DVD HacksSlysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
