VideoHelp.com Forum
Thread: VGA to RCA?
    I have tried to read up as much as I can about this.
    As far as I know I need some sort of box to convert the signal properly.
    I was wondering if they made cables which can bypass this.
    I have found this cables here: http://www.cablesnmor.com/vga-rca-cable.html
    Would these work for me or would I need something else?
    Regards,
    Colt
    Exactly what two pieces of equipment are you trying to connect together?
    M: Bond, I want you back.
    James Bond: I never left.
    A Laptop and a TV.
    I want to connect a Laptop to a TV.
    Most recent laptops have a video output meant to be connected to a TV. This connection is either a composite video RCA or an S-video (4-pin DIN). Either way you connect it to a TV then in graphics properties in control panel you invoke the secondary display and choose parameters for correct display on your TV. The resolutions encountered in a normal PC environment are higher than that required for TV display; the laptop converts these to that for TV and outputs it via these dedicated TV output connectors.
    Older laptops may not have dedicated TV outputs. Normal VGA CANNOT be converted to TV output merely by using ANY kind of cable. Even if you can successfully select resolutions and frequencies for a normal TV display there still remains the fact that VGA is RGB, with TTL sync, while video is either composite (everything in one wire) , S-video (color in one wire and luminance/sync in another) , or component (luminance/sync in one, color distributed in two other wires).
    To use a TV with your laptop that does not have a TV out you indeed need a VGA-to-TV video converter box.
    Would a DVI to RCA Cable work straight?
    http://www.bhphotovideo.com/bnh/cont...ist&sku=353560
  6. No, that won't work. You need a scan converter if your laptop does not have TV out...
    http://www.compusa.com/products/products.asp?N=200366
    That cable will work if your laptop's DVI connector outputs analog RGB, your TV has analog RGB inputs, and the TV supports the scan rates the laptop is putting out.
    RCA connectors are used for many different things. You need to specify what inputs your TV has. S-video, composite (yellow RCA), analog RGB (usually 15 pin DIN), analog component (YPbPr, red, green, blue RCA), DVI, HDMI?
  1. Which is best way to do video out to TV with laptop VGA or HDMI to RCA?
    By mjz55 in forum Newbie / General discussions
    Last Post: 7th Jul 2009, 05:15
  2. VGA to RCA/S-Video HELP!
    By eadavis in forum Newbie / General discussions
    Last Post: 7th Apr 2009, 07:52
  3. Weird Error - VGA to RCA
    By HamishT in forum DVD & Blu-ray Recorders
    Last Post: 7th Mar 2009, 20:18
  4. Laptop to TV using VGA and RCA?
    By JediMoonShyne2 in forum Newbie / General discussions
    Last Post: 9th Apr 2008, 15:51
  5. VGA to RCA (3)
    By jason in forum Newbie / General discussions
    Last Post: 8th Apr 2008, 11:45
