VideoHelp.com Forum
  1. Member Soopafresh's Avatar
    Here's the Free Method of Editing Out Commercials. If you can afford the $50, VideoRedo is a much simpler and powerful way to do the same.
    Note - This is for Mpeg2 Transport Streams, NOT AVC/h264.
    Tools Used: Mpeg StreamClip and Mpg2Cut2
    Edit: Couldn't find a screen capture program that cooperated with Mpg2cut2, so it looks like there isn't any video loaded when in fact there is.
    - Click on Thumbnails for Detailed Captions -
    Open Transport Stream With Mpeg StreamClip
    Choose "Save as Mpeg" from Menu. We're saving the file as "Capture.mpg" for reference.
    It Can Take a Few Minutes to Save the .MPG file
    Load Capture.mpg Into Mpg2Cut2
    Choose the Beginning of the Clip to Save
    Choose the End of the Clip to Save
    Click the + Button to Save that Segment to the "Saving Queue"
    Forward Past Commercial, Choose Start of Next Segment
    Once Again, Choose End of Next Segment to Save
    And Remember to Click the + Button to Add that Section to the "Saving Queue"
    Repeat for All Segments. When Done, Choose "Save All Clips"
    Imagehost - PicTiger
  2. Just buy the mpeg2 component for quicktime ($20) and then you can use MPEG Streamclip to do all the editing (download the January 2009 version of this component from your Apple Store account if you have an older version). Play the files using VLC -- MPEG Streamclip can play transport streams but sometimes has trouble playing the audio, even though it edits and transcodes correctly.
    Been using VideoRedo for a very long time and it is the program I have been most satisfied with. Well well worth the few $.
    And, there's a beta in progress for h.264 too so you might expect that to come out soon.
  4. Member Soopafresh's Avatar
    Definitely. One of the few editing apps that has no freeware equal. Worth every cent.
    "Quality is cool, but don't forget... Content is King!"
    PVAstrumento (free) also had a subset of VideoRedo (VRD) edit functionality and is used in almost the same way as VideoReDo; I used it for quite a while before I found the time-saving joys and reliability of VideoRedo.
    In VRD, I have a batch process which (i) QuickStreamFix the captured stream into an .mpg file (ii) runs AdDetective over the .mpg producing a project file of proposed cut points, ready for me to open and edit stuff in and out. Ad detective is 80-90% reliable (the channels "play games" with programs and ads, sometimes )
    You are so right, VRD was well worth every cent.
  1. Combine two transport streams.
    By Deadeditor in forum Newbie / General discussions
    Last Post: 13th Apr 2011, 08:12
  2. Seeking in Transport Streams(.TS)
    By deepp in forum Programming
    Last Post: 15th Jul 2010, 16:00
  3. Replies: 4
    Last Post: 2nd Oct 2009, 06:41
  4. Joining transport streams ?
    By NotSoEasy in forum DVB / HDTV
    Last Post: 3rd Jul 2009, 18:32
  5. European transport streams
    By branch in forum DVB / HDTV
    Last Post: 27th Mar 2008, 03:50
