i just formated my emachines T-3990, i used the 3 re-install cds to format the hd and then to re-install windows..
anyways.. it detected my intergated ethernet, but the driver is nowhere to be found on the reinstall cds. i went to the website, and they only have the driver for the 56k fax modem..
im using a very old terayon modem too btw..
so i have no driver to update the enthernet card that came intergrated on this pos emachines computer. so im so lost and have no idea what to do
i do Not have a regular full xp version on cd...
Thread: emachines ethernet driver?
By "Integrated" I assume you mean onboard ?
If so, try visiting the motherboard manufacturer's website and see if you can pick it up from there using your motherboard model no. Failing that, one of the chips on the motherboard will be for the ethernet, so try punching in some model no's off the top of the chips into google and see what comes up.If in doubt, Google it.
your onboard network chip is Intel® PRO 10/100Mbps integrated Ethernet
http://downloadcenter.intel.com/scri...Name=&lang=eng
thanks guys, ill try these!
driver worked perfectly mja, thanks again!
eMachines DV capture possible?
By GavSalkeld in forum CapturingReplies: 14Last Post: 27th Nov 2011, 12:50 -
second HD on old emachines
By mac71671 in forum ComputerReplies: 4Last Post: 18th Sep 2009, 13:51 -
Emachines EL1300G-01w DVD Burner
By Max Renn, Channel 83 in forum DVD & Blu-ray WritersReplies: 1Last Post: 29th Jul 2009, 10:38 -
HP Ethernet Driver
By Sportster Freak in forum ComputerReplies: 14Last Post: 19th Mar 2009, 18:02 -
Can i run a 8400gs on my emachines w3410
By davidsama in forum ComputerReplies: 1Last Post: 8th Dec 2008, 22:20
