VideoHelp.com Forum
    hey i split a wmv-hd for xbox360 and it plays on pc but 360 wont reckognize the split files. they are still in wmv format and i used Movica to split the files. anyone know why 360 would reckognize the original wmv-hd and not the 2 split files?
    Maybe try asfbin....or movica is based on asfbin but it may work better with the asfbingui.
    And doesn't windows media encoder also include a tool for cutting wmvs?
    does anyone know a splitter program that is compatible with 360??
    I use Boilsoft AVI/MPEG/RM/WMV Splitter and it works a treat, had a movie that was over 5gig and wanted to play it on my xbox360 using an external drive and as you have to have it formatted @ fat32 to enable the 360 to see it you can't have any file over 4gig on it...split it perfectly into 2 parts without loss of picture or sound quality.
    http://www.boilsoft.com/
    Hope this is helpful.
    Cheers
  1. Streaming to XBOX360
    By blueleo65 in forum Video Streaming
    Last Post: 25th Dec 2011, 21:23
  2. Xbox360 to pc capture
    By Bjs in forum User guides
    Last Post: 14th Aug 2011, 19:54
  3. Steaming to xbox360
    By tomchew in forum Media Center PC / MediaCenters
    Last Post: 13th Sep 2010, 10:37
  4. Converting MKV to WMV for the XBOX360
    By zilbermm in forum Video Conversion
    Last Post: 29th Oct 2009, 09:29
  5. Adding chapters to WMV file for use on Xbox360
    By brijazz in forum Video Conversion
    Last Post: 30th May 2007, 07:11
