I just converted a DivX file to MPEG and then I split the MPEG into CD burnable sizes. The conversion and splitting was done using TMPGEnc. When I attempted to create the VCD using Adaptec EZ CD Creator 4.0, It would not allow me to due to an error.
It would not accept the frame size of the MPEG file which was 352x128. This was the frame size of the original DivX file.
Can somebody please help me out on how I can fix my VCD creation problem? I'm new at creating VCDs and I'm not sure how exactly to fix this. I downloaded VirtualDub, because I think I'm supposed to use that to adjust the frame size. I'm just not sure if that is what I should be doing or if that is the right software to do it with.
Any help would be highly appreciated!
Results 1 to 1 of 1
Thread: Aspect Ratio Problem
By prismpecs in forum ffmpegX general discussionReplies: 1Last Post: 25th Oct 2011, 13:36 -
By maccool111 in forum Video ConversionReplies: 6Last Post: 29th Mar 2010, 07:58 -
Aspect ratio problem
By nlaak in forum DVD RippingReplies: 6Last Post: 4th May 2009, 16:13 -
By Renegade in forum Video ConversionReplies: 8Last Post: 2nd Mar 2009, 20:04 -
By Derin in forum Authoring (DVD)Replies: 4Last Post: 16th Aug 2007, 22:00
