VideoHelp.com Forum
    I'm trying to turn some *.M4V files into VCDs.... and it's starting to feel impossible (to do without buying 3000 different programs). SUPER won't do anything, YAMB will output a useless .MP4 file (and by useless, I mean "The movie contains some invalid data" error).
    I bought these files from the itunes store. Any suggestions? The Sonic burning software that comes with WinXP will make VCDs, just won't recognize .M4V as video.... I guess all I need is to convert this crap to something else then burn?
    Thanks!
    Your problem would be the DRM that Apple use. Not sure if there is anything that can strip it from the video files.
  3. Member GMaq's Avatar
    Hi.
    http://www.tunebite.com/en/tunebite/...d135766b38b6fa
    Check this out, the top of the line version supposedly copies DRM protected Audio and Video, don't know anything about quality though.
  1. What is .m4v?
    By kevs in forum Mac
    Last Post: 17th Jul 2011, 12:20
  2. Replies: 4
    Last Post: 5th Oct 2010, 16:15
  3. M4V vs. AVI
    By mkr10001 in forum Video Conversion
    Last Post: 29th Apr 2010, 10:03
  4. m4v to AVCHD
    By PSS2 in forum Authoring (Blu-ray)
    Last Post: 4th Apr 2010, 16:33
  5. m4v to DV
    By jscape2000 in forum Mac
    Last Post: 3rd Dec 2009, 12:41
