Hi
Can anybody help? Is there any way to convert video to cartoon? I know we could do it by After effect but I want to know whether we could convert video to cartoon by editing software like Premiere or not?
I am very interested in what kind of answers you will get. I found several sites to check out by Googling "rotoscope with software", because the analog method for this would be rotoscoping. I have previously found a free app called WAX that works with PREMIERE and VEGAS, though I have never tried it out. It's free and the site is: http://www.debugmode.com/wax/
Good luck.Old home videos are historical documents that may be best used to annoy your children.
BJ-M, Thanks for your answer, I checked it with photo and the result was good but I am going to use MSU Cartoonizer filter in video very soon.
But is there another way? Can we do it in Premiere?
http://www.google.com/search?hl=en&q...n+effect&meta=Originally Posted by Sean_ve99There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
I converted movie into cartoon by Photoshop and Premiere, the result was not bad but it could be better too, I hope professionals check this method and improve it.
I found a very good action in Adobe exchange that converts images into comic book style, it was made by Simon Wozniak (comicbook.atn), and you could search it here;
http://www.adobe.com/cfusion/exchang...cfm?view=sn710
I exported 30 seconds movie from premiere pro as Tiff sequences then I took them in Photoshop and used Automate Batch command to convert all images to painting by comic book action then I put them in Premiere Timeline and rendered, the result was good, every thing was like cartoon but there were some small shimmering dots and lines in scene that I could not omit them.
I don’t know is it good method or not but I would like to hear your idea, I hope you guys help me to find a way for improving its quality and solving shimmering dots.
New cartoon resolution
By CaZeek in forum CapturingReplies: 5Last Post: 18th Oct 2010, 11:22 -
Should cartoon video be interlaced?
By indijay in forum ffmpegX general discussionReplies: 11Last Post: 20th May 2010, 06:33 -
Video to Cartoon
By MarioB in forum EditingReplies: 1Last Post: 2nd Nov 2009, 09:30 -
Video editing programs letting you create .m2ts files with VC-1 video?
By justin0324 in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Mar 2009, 22:24 -
Creating cartoon video from JPG image
By richnz in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2009, 15:18
