It is pretty easy to run into A/V delay problems when using All-In-One transcoder apps (Super, Tmpgenc, ConvertXtoDVD, DVDSanta, many others, etc). BTW, these apps are all great, but they're only as good as the file you give to them to encode. A source file with bad frames, weird audio sample rates, vbr, etc will result in an encoded target file that has audio and video drifting out of sync. As this is a common question - "why did this happen and what can I do?" perhaps the following might help:
Here's a soopa simple batch file which will reduce (hopefully) the likelihood of A/V sync errors when you encode your DivX or Xvid file into MPEG or any other format. It does not touch your original files. The batch file processes a copy of your original, fixing existing problems with mencoder's indexing capability, decoding the audio to WAV, resampling the audio to 48000hz with the very high quality SSRC app, then muxing the clean AVI with the WAV into a new file which you can feed into your encoder. The execution is simpler than the explanation
NOTE: Your .AVI files can't have spaces in their names, otherwise the script will ignore them.
Bad: This Is My File.AVI
Good: This_Is_My_File.AVI
Instructions:
1) Download and extract Avi_Prep__v03.zip
http://www.rogepost.com/n/7070138433
2) Place your AVI files to be processed in the same folder as the avi_prep apps. It should look like this:
3) Double Click on AVI_PREP.BAT to process. Your original files won't be touched. The new files will be called "_Fixed-original-file.avi". The "Fixed" files will be a LOT larger than the originals - that's because they're only meant as food for your Mpeg encoder. Once you're done using them to encode, you can delete them.Code:AVI_PREP.BAT mencoder.exe ffmpeg.exe normalize.exe ssrc_hp.exe ReadMe.txt Some_Divx_File.AVI AnotherOne.AVI Even-More-Divx_Files.AVI
_Fixed-Some_Divx_File.AVI -------------> Give to your encoder
_Fixed-AnotherOne.AVI -------------> Give to your encoder
_Fixed-Even-More-Divx_Files.AVI -------------> Give to your encoder
It can take a bit of time to process the files, especially if they are large. - 10 minutes on a 700MB file. Make sure you have a fair amount of free disk space - 3-5 times the space of your original AVI files.
If the regular AVI_PREP doesn't work, try AVI_PREP_44.1.bat. It will resample the audio to 44.1Khz instead of 48Khz. In some cases, this will work better.
And remember - this won't fix the problem in every case. When that happens, present your file to this individual for consultation: http://www.mcpartlan.net/fonzie.jpg
Here's a small AVI test file with which you can try the script out.
testfile.avi
Results 1 to 18 of 18
This is a great utility!
I haven't tried it yet but I like the idea and understand the concept.
I do have a question though for you ... I downloaded a season (24 episodes or so) of this TV show and when I demux the audio (which is VBR MP3) I have to add 1 second of blank audio to the start of each audio file otherwise the audio is off by 1 second through (constant) from start to finish.
What I have been doing ... load the XviD AVI with VBR MP3 into GoldWave and add 1 second of silence to the start then save to a PCM WAV audio file. Then I use another program to convert the PCM WAV to an AC-3 audio file.
Usually GoldWave can extract VBR MP3 with no sync problems but for some reason this entire season (I've converted the first 6 episodes so far) needs this 1 second "delay buffer" added to the audio file to keep sync.
So is there way to use your script to do this? Would save me a hell of a lot of time
I'll give it a shot. OK, figured it out.
2 Apps Required
Silence http://jsoto.posunplugged.com/tools/...e_1201_exe.zip
Joinwav http://www.pc-tools.net/files/win32/...oinwav-1.0.zip
Silence.exe is pretty nice because it allows you to create silent wav, ac3, mp2 files at
your desired audio file settings - sample rates, channels, etc. You can choose the length of the silent wav by time in seconds or number of frames. In this example, it created a 1 second wav file of silence called Silence.WAV which you'll stick onto the front of the main audio track with the next app - Joinwav
Joinwav.exe Silence.wav Mainaudio.wav Output.wav
Of course, this assumes that the audio characteristics of the two input files are identical. In the customized script for Fulcilives, the joining takes place right after the ssrc_hp sampling rate modification so the two files will match - Silence.wav is stereo 2 track 48000hz, 16bit and so is the newly resampled main audio track.
Completely simple to modify the settings above to match your custom settings. Download the two files above and unzip them into the Avi_Prep folder. Also, specific to FulciLive's request:
fulcilives.zip
Thank you for the attentionOriginally Posted by Soopafresh
Now the XviD seems to play with perfect sync as is but when I convert to MPEG-2 DVD spec I have to add exactly one second of blank audio at the start of the audio file. I do this when I convert the audio to a PCM WAV audio file. Then I convert to AC-3 format. I guess I could just convert to AC-3 format first then use delaycut or AC3 Delay Corrector to add a delay of 1000ms to the AC-3 audio file which would do the same thing.
Here is the important audio stuff loading the XviD AVI into GSpot (v2.60 RC01)
So again if your script can do what it does now BUT add exactly one second (1000ms) to the PCM WAV audio file ... well ... that would be sweet
Wouldn't it better if it you could simply specify a delay of your choosing ? Not everyone needs exactly 1 second
I also wanted to mention that for those that use a all-in-one converter such as ConvertXtoDVD that your simple and easy-to-use batch file seems to be a great idea to use on the files before feeding them into ConvertXtoDVD or whatever other all-in-one program someone may use (I guess SUPER is another popular one).
You might want to make this more clear in your initial post in this thread.
See above
"Quality is cool, but don't forget... Content is King!"
I'll try it out as soon as I can ... thank you so muchOriginally Posted by Soopafresh
No problemo.
If you wish to purely create WAV files for eventual transcoding to AC3, then the same rules as above apply - no AVI files with spaces in the name
Save as WavPrep.bat
The resulting WAVs with the second of silence will be named S-AviFileName.wavCode:dir *.avi /b >avilist.txt for /f %%a in (avilist.txt) do call :process "%%a" goto end :process del yg.wav ffmpeg -i "%1" -vn -y "%~n1.wav" ssrc_hp --rate 48000 --bits 16 --dither 1 --pdf 1 1 "%~n1.wav" yg.wav Normalize -l 0 --peak -v yg.wav Joinwav Silence.Wav yg.wav S-"%~n1.wav" :end
Hi,
I have tested your batch file and it seems to works OK.
Is it possible to make some batch file that fix audio-video synchr in vob ore mpeg files?
Peter, Belgium.
Soopafresh
Would love to try this, can't seem to be able to get a non-damaged zip file from that link.
Any other location for d/l?
Cheers,
Sure thing. I'll post it elsewhere. Hope it helps, I've been thinking about ways to make it a bit better --> more sync oriented.
Note: The shorter the AVI clip, the better your chances are of the script working in your favor.
Note: If you try it and the resulting file ISN'T in sync, try the following -
I've included an additional batch file in the link below - AVI_PREP_44.1.bat
If the regular AVI_PREP doesn't work, try AVI_PREP_44.1. It will resample the audio to 44.1Khz instead of 48Khz. In some cases, this will work better.
http://www.mytempdir.com/1243295
Hi, thanks for replay,
Example for dvd?
Is it possible to make a batch file that join all the vob files from a dvd, make 1 large mpeg that have a perfect video - audio synchronisation.
Thanks in advance.
Peter, Belgium
the link for Avi_Prep__v03.zip doesnt work...
Sorry, man. I don't have it any longer. Just as well, technology has advanced enough that it's no longer needed.
i see well ill look around for other options guns1inger just gave me something to try but thanks for the response i appreciate it (; too bad cuz your guide seemed simple enough for me to fix my issue lol
A simple, no fuss way to prepare clips from a DVD to upload to YouTube
By G)-(OST in forum User guidesReplies: 9Last Post: 10th Nov 2009, 21:35 -
Saving multiple AVIs from 1 AVI by virtualdub script
By DveD in forum EditingReplies: 1Last Post: 16th Oct 2009, 08:47 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 19:05 -
Simple DirectShow script for virtualdub
By streamking in forum Video ConversionReplies: 2Last Post: 28th Jan 2009, 14:43 -
Trying to write a simple batch script for VDubMod
By mob in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2007, 19:39
