VideoHelp.com Forum
    Using Windows XP, can anyone suggest the best software to batch rename m4v video files? Also can anyone suggest the best m4v join software? yamb does not seem to work for me. Thanks Phil
  2. Member GMaq's Avatar
    Hi,
    If iTunes isn't an option, there is an application called Atomic Parsley that is good for tagging, YAMB is usually the ticket for joining, it probably doesn't like re-muxing the .m4v files, if these are for an iPod there is a special version of mp4Box called Nicmp4box that should do what you want, I'm not great with commandline, so I really can't explain how to do it,
    Nicmp4box is here http://nic.dnsalias.com/NicMP4Box.zip
    Google Atomic Parsley, I'm not sure where to get it, The Doom9 forums are a good place to look
    Thanks. Is Atmoic Parsley a mac or XP program? I am using XP. Also, on NICmp4box, how do I use that? Regards Phil
  4. Member GMaq's Avatar
    Atomic Parsley is open source I believe, I have it inside another program on XP, You could try replacing the mp4box in YAMB with the Nic one and see how that works, just make sure you backup the old one and have the program (YAMB) handy in case it doesn't work and you have to re-install
    Nic modified mp4box so that it would output 640x480 AVC mp4's that iPod's would play. Otherwise it should behave the same as a regular build and if you don't have 640x480 AVC mp4's then a regular version should behave the same as Nic's modified one.
  1. Join m4v splitted with mp4tools?
    By Cartman in forum Video Conversion
    Last Post: 10th Jan 2012, 16:12
  2. What is .m4v?
    By kevs in forum Mac
    Last Post: 17th Jul 2011, 12:20
  3. M4V Video Not Compatible with Editing Software
    By Craig Taylor in forum Authoring (DVD)
    Last Post: 20th Jun 2011, 11:09
  4. Replies: 4
    Last Post: 5th Oct 2010, 16:15
  5. m4v to DV
    By jscape2000 in forum Mac
    Last Post: 3rd Dec 2009, 12:41
