Hi,
I wonder in witch format is a video, that can be viewed on a Sony-Ericsson p990? (symbian os uiq 3.0)
Thx in advance, all answers is appreciated
//Peter from Sweden
3gp - Try 3gp converter or Nokia MultiMedia Converter
/Mats
can I really use Nokia for Sony Ericsson? and the convertion for p990 is the same way as the convertion for ipod?Originally Posted by mats.hogberg
Not the same settings, but the same tool. And yes, Nokia MM Converter works for SE. Used it with my P800. For my more current z550i, I use 3gp converter, 3gp2+AAC General setting (w/o 3gpp2 header), QCIF Normal q at 1/2 original frame rate (12.5 for 25 fps source).
Excellent q for the small screen, both audio + video. Can fit 4 full length movies on 1 GB mem.
/Mats
thx Mats, IŽll try it
Witch one do you suggest I should use for my p990i?Originally Posted by mats.hogberg
And what do you mean by3gp2+AAC General setting (w/o 3gpp2 header), QCIF Normal q at 1/2 original frame rate (12.5 for 25 fps source).
That's the preset I use for z550 in 3gp converter.Originally Posted by ptrlks
/Mats
ok, after reading many many different posts about video on my newly aquired P990i I finally got it working using AVS video tools and creating a 3gp file.
one issue.................I started to convert pitch black and then stopped it for some reason I can not recall then started it again and let it run through I copied it to my phone and it came back and said it cant play movie want to try again...........#$%#@!
so for kicks and giggles I copied up the one that I had stopped about half way through the conversion and it played!!!!
the only difference is that the full copy (that wont play) is 122 meg
the one that (will play) is 49 meg
anyone have anything similar happen to them?
btw I have a 1 gig scandisk card so I would not think memory is an issue
tia
converting Format 35 Youtube video to H.264 on Mac for iPod viewing
By Tokyoguy in forum MacReplies: 12Last Post: 31st May 2009, 00:33 -
Converting video for Sony Ericsson W950i using ffmpegx
By Chris_D in forum ffmpegX general discussionReplies: 4Last Post: 24th Aug 2008, 07:19 -
Help with Philips DVP5960 and Sony Ericsson K800i over USB
By lucky23 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jan 2008, 05:36
