VideoHelp.com Forum
    Hello,
    I have been burning a lot of softsubs (.srt format) into AVI files recently using ffmpegx with no issues, and today a problem came up.
    My first attempt to convert this file went normally, but after conversion I realized that the aspect ratio of the original file was off (512x480 as opposed to 640x480 like the rest of the episodes in this series). I attempted to reconvert the old file using the 4:3 aspect ratio (which autoset to 512x384) with all the exact same settings as the first time, but the progress finished immediately and the created file was zero kb. I retried this several times (one time with the aspect ratio set to 640x480), always with the same results. I also tried encoding the file again without changing the aspect ratio, and it still converts fine.
    Settings info:
    -Original File-
    This is what ffmpegx tells me when I click the "Info" button on the upper right (next to play).
    VIDEO: [XVID] 512x480 16kbpp 29.970 fps 1215.9 kbps (148.4 kbyte/s)
    audiocodec: framecopy (format=55 chans=2 rate=44100 bits=0 B/s=16000 sample-1)
    Of note: all other episodes in the series show [DX50] as opposed to [XVID] in the above information (as well as some differences in fps and kbps and such, but I don't think that's really relevant).
    -Created File-
    XviD [.AVI] (mencoder), 1215.9 kbit/s, 512x384, subtitles position set to 95. All other settings are kept at default.
    Also of note: I used the "DivX 3 [.AVI] (mencoder)" codec for one of the conversions and still got the same results.
    Log file:
    Encoding started on Fri Feb 2 10:45:16 EST 2007
    FIXME:Hardenabling SSE and SSE2 without detection
    MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    Mac OSX static build for ffmpegX
    CPU: Intel (Family: 6, Stepping: 8)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    success: format: 0 data: 0x0 - 0x1c624c06
    AVI file format detected.
    VIDEO: [XVID] 512x480 16bpp 29.970 fps 1215.9 kbps (148.4 kbyte/s)
    [V] filefmt:3 fourcc:0x44495658 size:512x480 fps:29.97 ftime:=0.0334
    Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
    AUDIO: 44100 Hz, 2 ch, s16le, 128.0 kbit/9.07% (ratio: 16000->176400)
    Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
    SUB: Detected subtitle file format: subviewer
    SUB: Read 660 subtitles.
    SUB: Adjusted 505 subtitle(s).
    xvid: using library version 1.2.-127 (build xvid-1.2.0-dev)
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=512 h=384]
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
    MP3 audio selected
    VDec: vo config request - 512 x 480 (preferred colorspace: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    Hopefully this is enough information to get my problem solved...
  2. Member terryj's Avatar
    hate to tell you this, but you want to post this in the ffmpegx
    forum.....
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    forum.....
    Ah, thank you. I had just signed up and couldn't post anywhere else, so I just stuck this on the newbie forum. Apologies for that.
  1. Converting OGM files to AVI/MPEG with subtitles
    By StevoK in forum Video Conversion
    Last Post: 4th Feb 2010, 01:50
  2. Topfield rec to avi with burned subtitles
    By Markomaani in forum Video Conversion
    Last Post: 19th Mar 2009, 06:29
  3. AVI to iPhone with subtitles burned in
    By voiceinabox in forum Mac
    Last Post: 28th Apr 2008, 09:10
  4. Replies: 2
    Last Post: 30th Nov 2007, 13:23
