Hi folks,
this is my first post, so if I should be in the wrong sub-forum, please be kind and don't send me to hell.
I'm experianced in creating VCD/SVCD with TMPGEnc, actually I use Version 2.00. Sources are mostly DV-tapes (avi). Results are pretty good after doing many experiments with settings. Maybe we can discuss that another time.
I would like to create mini-DVD's (on 700MB-CD-R). How to do it? Can I use my favorite Tsunami-Encoder further? And can I author with the latest Nero-version? Do I need any other tools? What's the resulting maximum length of a miniDVD?
BTW, TMPGEnc causes most of times ugly distortion (probably k3,k5...) in the sound files. So I use my Video-editing-prog to make a separate VCD- file and remux the resulting audio-file with TMPGEnc-Video-file. Works great, but uncomfortable. Anyone has a clue?
Thanks a lot for your answers.
regards
grommi
Thread: How to create a mini-DVD?
All right
Although I am still experimenting with videos but I also experimented with Mini DVD. I think that you think that you think you can burn a Mini DVD to a normal CD. But that is not true. Mini DVD is a sort of video that you have to burn on a DVD disc and a normal CD.
To make a Mini DVD you could use Spruce Up, it is a very nice program. You can do a lot of nice things.
I hope my information is correct, if not, just forget all this
But I think all this correct for 90%.
Greetings,
Bartjuh
Ulead's DVD Movie Factory app will make mini-DVDs on CDR. Unfortunately my DVD player won't read it.
My computer plays it just fine though.
vcddude
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum CapturingReplies: 4Last Post: 8th Feb 2011, 17:27 -
Extract/Create Mini DV Metadata and etc...?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD)Replies: 139Last Post: 23rd Nov 2009, 07:01 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36
Statistics
Newest guides
Latest tool updates
New media comments
