VideoHelp.com Forum
Results 1 to 17 of 17
    Type: System.UnauthorizedAccessException
    Source: mscorlib
    Message: Access to the path "C:\Program Files\BadgerIT\SVCD2DVD v2\menu\MenuMuxer.exe" is denied.
    I have used this program for ages and encode easily with no problem on vista 32 but i tried to use a menu and got the following error.
    Im assuming the specified path is the right one and the actual application it is trying to reach is missing.
    I would use nero for the menu but this is so much quicker as almost everything has been converted to s2d files meaning i really need to get this sorted.
    Any help would be great thanks.
    Sorry just noticed through playback too the 1st time i tried to include chapters this also failed.
    I did set it to 10 minutes and applied it to override svcd's own settings but no chapters.
    Im sure its a vista thing as everything worked on xp but i hate xp so a solution would be awesome.
  3. Member ChrissyBoy's Avatar
    Source: mscorlib
    Is this when previewing a menu or during the actual processing?
    It creates the titleset and as soon as it tries to start the menu i get this error, also i got an error when trying to preview but i dismissed that and didnt keep the text, sorry.
    I thought maybe it was the uac so i set everything to run as administrator, but no joy and found that menumuxer is in the svcd folder and has no seperate menu folder as the path asks for so i have created the folder "menu" and copied the file to it....i will run it now and report back findings asap.
    ok did that and got this, so at least its a different message.
    Version: SVCD2DVD 2.1
    Build: 2.1.2474.30185
    Type: System.ArgumentException
    Source: mscorlib
    Message: Invalid File or Directory attributes value.
    InnerException:
    StackTrace: at System.IO.File.SetAttributes(String path, FileAttributes fileAttributes)
    at x3284ccece41ee22b.xe679539bc4bbd8b5.x865d1dce05e7a 87c(String xc7faa4629ea73ace, Boolean x1ebdb8fb1e9908a0)
    at x3284ccece41ee22b.xddb8d1ea6c9958c7.x8291881ef07bb 5c7(Boolean x7ce1fdb24a74c398)
    at x3284ccece41ee22b.xd3764d4f1e921081.x4f3432523597d cf6(Boolean x7ce1fdb24a74c398)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
  7. Member ChrissyBoy's Avatar
    I think (off the top of my head) - what it is trying to do is to delete the folder, before it recreates it. It maybe that allowing full control to C:\Program Files\BadgerIT\SVCD2DVD v2 (and child folders) to the account you are logged in as will resolve the issue.
    sadly that didnt work and wont let me preview a menu either.....the code for that is in the other menu problem post as it seems to be the same problem.
    Uninstalled and reinstalled, gave program full acess over folder and now on the program ending the titleset and trying to encode a menu i get this error, so any clues on where to go from here.
    Type: System.ComponentModel.Win32Exception
    Source: System
    Message: The requested operation requires elevation
    InnerException:
    StackTrace: at System.Diagnostics.Process.StartWithCreateProcess( ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start()
    at x3284ccece41ee22b.xc5b4b7804027a156.x160a0bf4de8f6 bd0(String xd168ac2ed64c4662, String xa6a477a49a1a2599, String x450f47a9028f884b, xa0efedb9fec1e88f x8b49c96cd0348808, Boolean x74effd3a0f44569e)
    Right i came from here and closed the program after the last message and windows popped up a pretty little window telling me a program had not run right and had adjusted the settings to make it more compatible.On trying again it got to the menu creation part and vista told me that an unauthorised program wanted to run what do i want to do, obviously i allowed it but then got this error on allowing it.....I dont understand why its denied because everything thats allowed to have permission over this program has it from trusted installer to me and to admins(which i am).
    So full controls failing and windows attempt at making it work created the following.
    Source: System
    Message: Access is denied
    InnerException:
    StackTrace: at System.Diagnostics.Process.set_PriorityClass(Proce ssPriorityClass value)
    Source: mscorlib
    I know it is no help but I have just bought Vista Home Premium and I am having the same problem I have emailed Badger and hopfully a solution to this problem will arise and we can continue using this outstandng program
    Mick Porter
    CREWE
    Cheshire
  12. Member ChrissyBoy's Avatar
    Orakal: Can you try re-installing the program but this time choose a folder other than "C:\Program Files"?
    Got an Email from ChrissyBoy and am converting a film whilst at work informed that program is still running.
    Many Thanks ChrissyBoy
    Mick Porter
    CREWE
    Cheshire
    yes ill try it, any suggestion as to where?, or will partiton D:/ do?
  15. Member ChrissyBoy's Avatar
    Well anywhere really... D:\SVCD2DVD would do the job (i think)
    Installed on D but still not able to preveiw a menu, just started to code with a menu so i guess we'll see but im not hopeful.
    Oh well im not afraid to admit im wrong lol......It worked i have a newly encoded dvd with a menu.
    I installed it straight to D as installer was having none of it trying to put it into a folder named SVCD, so i have files all over D relating to svcd2dvd but it worked so ill just reinstall it again and find a place for it.
    So it would appear to me to be a problem with Vistas UAC even when system and myself had full rights,but im using the last demo build maybe the full release will be ok.
    Thanks alot for the input Chrissyboy youve been a great help and should i come across any other problems or solutions to other problems here ill be sure to post.
  1. trouble with SVCD2DVD menu selection highlighting
    By bobarnett in forum SVCD2DVD & VOB2MPG
    Last Post: 4th Sep 2011, 14:59
  2. SVCD2DVD Error when encoding menu??
    By gsmb in forum SVCD2DVD & VOB2MPG
    Last Post: 23rd Feb 2011, 13:44
  3. Really strange SVCD2DVD menu problem
    By denali in forum SVCD2DVD & VOB2MPG
    Last Post: 4th Oct 2009, 11:41
  4. svcd2dvd problem
    By dvds2u in forum Newbie / General discussions
    Last Post: 27th Mar 2008, 11:05
  5. SVCD2DVD problem with TS files
    By rickfaldo in forum SVCD2DVD & VOB2MPG
    Last Post: 26th Dec 2007, 11:14
