hello people. i am trying to load a .sub file on media player classic after opening a file. i also read previous posts so i know that the output is suppose to be on VMR9 (renderless). so once i have opened the video file and it has begun playing in the background, i go to file>load subtitles> and select the .sub file i have. and thas it no error no nothing. but wen i go to navigate>subtitle language its grey. i can't even select it. this tells me that the subtitles never got loaded. i also didn't see any subtitles while the ppl in the video are speaking. wats wrong?
Try to open your .sub file in Subtitle Workshop to see if you have a textual form of a subtitle. Try to convert it to .srt format and load again in MPC.
But the best and easiest subtitle support in recent players, you will find in KMPlayer.
GOM player is the other fine option, as well.
well wen i try to open the files subtitle workshop gives me an error of bad subtitle or unsupported format. so wats wrong? also how do i convert it to .srt file.
Typically, if subtitle workshop can't open the file, then the file is corrupt. Which would also explain why is doesn't work with MPC. Try to find another copy.
Google is your Friend
i say try VobSub before looking around
Open the file with a text editor (eg, Notepad).Originally Posted by sajjadbaqir
If you see binary garbage, then you have a bitmap /image subtitle. Subtitle Workshop can only use text format subtitles.
Try DVDSubedit, it can open bitmap subs, and OCR them to text. Do spellcheck after doing that, OCR isn't perfect.
I found once that with using a sub file (sorry I know it was textual but don't remeber the format) that the sub wasn't working because it was not the correct format.
Basically when I opened it in note pad I saw like timing and words starting from 00:00:00:00 however at the top I saw
Sub for blah blah blah
Encoded by Enzo
Some other stupid message.
After making a copy of the file I deleted anything that was like what was in the rest of the file. It worked after that.
Media Player Classic not loading DirectVobSub
By Ashed in forum SubtitleReplies: 3Last Post: 9th Oct 2009, 11:43 -
Media player classic - loading subtitles
By jujuandhuhu in forum Software PlayingReplies: 5Last Post: 19th Dec 2008, 09:26 -
ffdshow, media player classic, subtitles
By rkovideo in forum Software PlayingReplies: 10Last Post: 8th Jan 2008, 22:12 -
subtitles not showing up on media player classic
By cdcmoon in forum SubtitleReplies: 1Last Post: 1st Nov 2007, 03:06 -
Media Player Classic + SRT Subtitles
By Basketbits in forum SubtitleReplies: 3Last Post: 17th Jul 2007, 03:53
