I was capturing from TV with WinDVR in MPEG-2 and Pinnacle PCTV Pro TV Tuner and my computer suddently rebooted so the capturing was interuppted abnormal. I checked the recorded file and it was about 11GB but the I can access only the 5.3GB of that file with the VirtualDub Mod or the DGIndex or the TMPeg. I made a copy of that file in another location of my hard disk and no problem so the file on the hard disk doesnot have any problem. I tried to find a program that repairs Mpeg-2 and I found about 8-10 but they didnt help. They stopped at the same position (5.3GB) of the file. Then I tried with a file splitter to split the file in smaller parts to check if I could open the last parts of the file. The parts that were created before the position of 5.3GB opened OK with any program. But the parts beyond 5.3GB of the 11GB of the file didn't seem to be accessible by Virtual Dub Mod or DGindex.
Does anyone know if it's possible to fix such a file or how to fix interrupted recordings of WinDVR?
If it helps I can upload a small part of the file (500kb) that is not accessible and another part that is accessible.
Results 1 to 1 of 1
Thread: Interrupted Capture with WinDVR
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video StreamingReplies: 3Last Post: 15th Dec 2010, 17:32 -
Interrupted WinDV Capture...Now I can't play the AVI file.
By ione in forum CapturingReplies: 11Last Post: 18th Oct 2009, 08:52 -
TV Tuner / Capture Card - WinDVR 3 no Audio after Windows Vista install
By buzzsaw in forum CapturingReplies: 20Last Post: 12th Oct 2008, 15:06 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 19:01 -
resume an interrupted lightscribe burn???
By cduval04 in forum MediaReplies: 9Last Post: 8th Jan 2008, 21:23
