I am new to this software but have used it to convert other file types with ease. I have a sony digital camera that records fairly good quality video clips. It records in MPG format which is not usable with iMovie. I have tried to convert a clip with ffmpegX to all possible file types but nothing happens. All I get in the end is the new file with the correct file type name on the end... but the file size is 0 and the conversion takes only 1 second to complete.
If anyone can help...please.
Please post the log (
) in order to look for an error in the conversion.
Hey that was fast....here it is
Encoding started on Sun Jan 28 15:19:40 CET 2007
Input #0, mpeg, from '/Users/jasonswinehammer/Movies/MOV00844.MPG':
Duration: 00:02:02.4, start: 0.110000, bitrate: 2927 kb/s
Stream #0.0: Audio: mp2, 32000 Hz, mono, 64 kb/s
Stream #0.1: Video: mpeg1video, 640x480, 25.00 fps
Codec type mismatch for mapping #0.0 -> #0.0
thanks
Audio stream listed before video stream, resulting in a mismatch for mapping. With some files that happens.
Tick the Invert mapping checkbox in the Audio tab. Then try again.
Does Imovie Work Better with H264 ?
By smartduck in forum MacReplies: 1Last Post: 30th Oct 2009, 07:08 -
which format should i export my imovie projects to
By Lu-min Chew in forum Video ConversionReplies: 1Last Post: 6th May 2009, 02:18 -
n00b: Best format for iMovie '08 and '09
By dagware in forum ffmpegX general discussionReplies: 1Last Post: 21st Jan 2009, 11:27 -
iMovie Format?
By m.hofer in forum MacReplies: 1Last Post: 20th May 2008, 09:55 -
Convert from VIDEO_TS to iMovie compatible format
By Video Star_2 in forum MacReplies: 4Last Post: 11th Apr 2008, 12:53
