VideoHelp.com Forum
    hi there, just got this dvd player, but fo some reason it will only play some muli region dvd;s and not others, mabye its not actually multi region?
    anyone know a hack for this new model of tevion? have tried some of the old hacks i've found here but nothing has worked.
    thanks
    jason
    I just bought myself one of these as well. To get into the hidden setup menu which allows multi-region do as follows.
    Open the DVD/CD drawer. With it open press 9735 on the remote. A menu will appear. Select "0" for multi-region. Exit the menu.
    thanks, wrked great
    j
    just wondering if anyone lese has this dvd player, i find with copied dvd's (backups) that sound sometimes lags or is funny, but the same dvd's work fine in laptop,
    thanks
    jason
  5. Member Krispy Kritter's Avatar
    Most likely the player doesn't like the brand/type of discs that you are using. Try a different brand/type of media.
    Google is your Friend
  1. Aldi Tevion DD1018 MacroVision setting
    By tevionShopper in forum Newbie / General discussions
    Last Post: 22nd Apr 2009, 06:14
  2. Region hack required for Tevion DVD3602UKT player
    By mfraser in forum DVD & Blu-ray Players
    Last Post: 6th Sep 2008, 11:07
  3. Tevion TEV1020 DVD player - parts list, hack, connector pinouts
    By fzabkar in forum DVD & Blu-ray Players
    Last Post: 11th Jun 2008, 21:26
  4. Aldi/Tevion DVD recorder "HDD DVD 160 MkII" - tech info, region f
    By fzabkar in forum DVD & Blu-ray Recorders
    Last Post: 11th Jun 2008, 21:04
  5. multiregion hack for tevion 7072 dvd player wanted
    By fatboy1978 in forum DVD & Blu-ray Players
    Last Post: 22nd Aug 2007, 01:52
