Hi. I have a _NEC DVD_RW ND-2510A burner. It's max speed is 8x. I'm trying to burn dvd's using 16x dvd discs but my burner rejects them everytime I put them in. So I need to upgrade my firmware so my burner can use 16x dvd's but I don't know how. Can someone help? I'm afraid of damaging my burner if I don't do it right.
Thread: Upgrading my firmware
Here are where to download the firmwares. Depends on what capabilities you want.
Here as in videohelp.com? or did u forget to put in the link.
Just google for ND-2510A
The update should come with instructions on how to do it.
All of the information that you need is on the NEC website, which is where you should be getting the firmware. There are typically two ways. The old boot disk method and the update from within Windows method. The last few upgrades for me were from within Windows.
Google is your Friend
Well, I didn't realize the link didn't post. I definitely pasted it.
Lets try again.
http://liggydee.cdfreaks.com/page/en/NEC-ND-2500A/
MediaCodeSpeedEdit will show you what media codes in your firmware are set to burn at a given speed, it will also let you experiment (at your own risk to the media) by letting you set a media code to burn faster than rated.
http://www.videohelp.com/tools?tool=MediaCodeSpeedEdit
This is double post.
Check my answer in the other thread => http://forum.videohelp.com/viewtopic...654191#1654191
Converns about upgrading firmware...
By Dave Stewart in forum DVD & Blu-ray WritersReplies: 7Last Post: 8th Aug 2010, 08:43 -
Need help with upgrading
By jaywestcwf in forum CapturingReplies: 2Last Post: 10th Feb 2010, 10:19 -
help reqd. in upgrading firmware of my DVD player
By mohit in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 10:17 -
Help Upgrading Firmware for Samsung SH-S203N
By mn072065 in forum DVD & Blu-ray WritersReplies: 14Last Post: 8th Jul 2008, 05:50 -
Upgrading firmware
By tee jay in forum DVD & Blu-ray WritersReplies: 3Last Post: 26th Feb 2008, 13:35
