VideoHelp.com Forum
Thread: mac mini help?
    i have a mac mini and starting today for no reason it turns off it turned off like 5 or 6 times and when i try to turn it on nothing happens for a while i click the power button and i see the power light on but i dont hear the noise that you here when u turn it on. so i keep repeating the same thing a few more times then it comes on. also the times it does not turn on when i see the light if i put my ear up to the mini i hear an small noise. also i have a memory problem but i had this problem for a long time because one min i could have 5gb then another min i could have 50gb and i dont delete or dl anything eather.
    Bad power supply.
  3. Member terryj's Avatar
    Actually taking it step by step:
    1. No Boot Chime when Power Button is depressed
    2. Several attempts finally get it to recognize power
    3. A small noise occurs when when it doesn't turn on.
    4. Available HD status is faulty, one minute the HD reports
    5GB available, the next 50 GBs avaialble HD Space.
    (The max a mini can hold is 1GB, so this actually points to
    available HD/Virtual Memory Space, not Physical Ram).
    Since power is apparently there, and #1 and #4 most definitley
    point to faulty logic board, I would diagnose as a new logic board
    after a half split, testing your power supply and HD on a
    good known Mac Mini. Although I can't hear it, I would guess
    that #3 is actually your logic board trying to tell you a POST
    beep to let you know it is the logic board.
    hope you got AppleCare..if so, what are you waiting for?
    take it to the nearest ACRS.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    If you dont have Apple Care (but your mini is under the one year limited warranty), buy it, wait thirty days, then report the problem to Apple.
  5. why wait 30 days?? If you are in the 1 year you have a warranty, be it a limited one, and if you buy the applecare you can call that day and report the problem.
    Make sure you register your AppleCare online so you have confirmation your computer AND the AppleCare are in their system. Once that's done, the thirty day wait should not be necessary.
  7. Member terryj's Avatar
    Yup, I concur with rump and Ant.
    Urban Mac User
    I'll bet it's not often one may write the words quoted above and expect them to make sense.
  1. HDMI Splitter with Mac Mini Help
    By Premo in forum Newbie / General discussions
    Last Post: 28th Sep 2011, 01:06
  2. Mini DV To Mac
    By mvtm in forum Mac
    Last Post: 22nd Sep 2011, 23:25
  3. Replies: 0
    Last Post: 29th Dec 2009, 13:26
  4. MAC MINI
    By ozab in forum Editing
    Last Post: 29th Jul 2009, 11:09
  5. Mac Mini to TV quality?
    By whoisquilty in forum Mac
    Last Post: 11th Jan 2009, 10:57
