I installed VOB2MPEG some time ago and was able to convert VOBs without any problems but just recently I can no longer use this APP. No matter if the VOB is on a disk or on the hard drive I get (Finished Processing 0 VOBSETS Duration 00:00:03) I have un-installed, updated and re-installed version 2.3 also I have installed Net.Framework 2.2 as I believe this is needed. It has been some time sense I've used this APP. and I can't imagine that I've completely lost my mind in usnig it properly. Maybe I have!!! can those who use this program help me out ?? My objective here is to re-edit video that has been recorded on a DVD Desktop recorder. IE our church play! ETC.! Thanks in advance
GT
Thread: DVD to AVI using VOB2MPEG
"You have not because you ask not"
James 4:3
Your version of the program may not be completely compatible with Net 2.2. I'll move this post to the SVCD2DVD General Forum and ChrissyBoy may be able to give you better advice.
This will be my second SOS HELP! I've had 85 hits on this request with no reply, Chrissy Boy can you help?. Can anyone help? I sure would appreciate it.
I installed VOB2MPEG some time ago and was able to convert VOBs without any problems but just recently I can no longer use this APP. No matter if the VOB is on a disk or on the hard drive I get (Finished Processing 0 VOBSETS Duration 00:00:03) I have un-installed, updated and re-installed version 2.3 also I have also uninstalled .Net Framework 2.0 and re-installed it. It's been about 5 months sense I've used this APP. and I can't imagine that I've completely lost my mind in usnig it properly. Maybe I have!!! can those who use this program help me out ?? My objective here is to re-edit video with Vegas 6 that has been recorded on a DVD Desktop recorder. IE our church play! ETC.! Thanks in advance
GT"You have not because you ask not"
James 4:3
Originally Posted by GT Music
Um, actually, if a file is on the hard drive, it IS already on a disk (hard DISK drive). So maybe the question would be if the file is on the hard disk or on a removable disk or disC (and then to that you could say here that no matter what kind of disk or disc the VOB is on, you have that problem).
In case anybody is still having this problem (I was...), here is a possible solution: in my case, the disk where I was trying to save the output was full...
Seems that VOB2MPEG reacts to that by just stopping the conversion when the disk is full with the message "finished processing".
Extracting VOB from DVD, VOB2MPEG jacks up the video
By scottlindner in forum DVD RippingReplies: 13Last Post: 3rd Apr 2012, 12:20 -
VOB2MPEG no VOBSET Mode
By planeo in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Mar 2011, 10:59 -
cannot install vob2mpeg pro
By rodee728 in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 30th Mar 2010, 16:53 -
VOB2MPEG 3 error
By SWBisbee in forum Newbie / General discussionsReplies: 21Last Post: 20th Mar 2009, 16:41 -
VOB2MPEG Problems
By CompletelyLost in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 22:01
