VideoHelp.com Forum
    I searched the forums and the net on methods to burn The Davinci Code backup to dual layer media. So far the results have been 5 coasters.
    My problem is unique to most that I have read about though. Basically half way through the burn it errors out. I will list what I am using and the error messages I have received and maybe one of the guru's here can help me out.
    Specs:
    DVD Drive: Sony DRU-810A Firmware 1.0e
    Media: Memorex DVD+R DL
    Dell 8400
    I have burned many Dual Layer discs using this computer / drive / media. The only changes I have made have been a firmware upgrade to the DRU-810A from 1.0d to 1.0e. I have had successful burns since then though.
    Method 1:
    RipIt4Me 1.6.4.0(Wizard)
    Full DVD Mode
    DVD Decrypter 3.5.4.0
    Import PSL
    Fix VTS 1.6.0.2
    (No errors)
    Opened in DVD Shrink 3.2.0.15
    (no errors)
    Set DVD size to DVD 9
    with remove layer breaks (Checked) (I later found out that this is not a good method although I have used it and it has worked on other dual layer burns)
    Burned
    Nero 6.3.1.13
    Error in burn half way through
    Method 2:
    Full DVD Mode
    Import PSL
    Fix VTS 1.6.0.2
    (No errors)
    (no errors)
    with remove layer breaks (Un-Checked)
    Burned
    Nero 6.3.1.13
    Error in burn half way through (I saved the log this time)
    7:57:46 PM #26 CDR -1206 File DVDPlusDualLayer.cpp, Line 1520
    Burning Layer 2
    7:57:46 PM #27 Text 0 File DVDPlusDualLayer.cpp, Line 1527
    Perform layer 1 to 2 jump before writing at address 1973600 (1E1D60h)
    7:58:22 PM #28 SCSI -1135 File Cdrdrv.cpp, Line 1441
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x013B0000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x1E 0x1E 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
    0x00 0x00 0x00 0x00 0x0C 0x00
    7:58:22 PM #29 CDR -1135 File Writer.cpp, Line 304
    Write error
    7:58:22 PM #30 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    7:58:22 PM #31 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    8:00:48 PM #32 Phase 38 File APIProgress.cpp, Line 273
    Burn process failed at 2.4x (3,324 KB/s)
    8:00:48 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 828
    DRM: DRM burn session terminated.
    8:00:48 PM #34 Text 0 File AudioCompilationImpl.cpp, Line 857
    DRM: Closing entire DRM handling. Bye.
    Existing drivers:
    File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 11:07:32 AM
    File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 10/20/2006 11:14:43 PM (Prassi/Veritas driver for win 2K)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    Method 3:
    Full DVD Mode
    Import PSL
    Fix VTS 1.6.0.2
    (No errors)
    (no errors)
    Closed DVD Shrink
    Opened in IMGBurn 2.1.0.0 (Cause I heard this is the better way to do it)
    Followed the IMGBurn Instructions on burning a dual layer DVD from the guide here on Videohelp.com
    Chose the best Layer Break according to IMGBurn
    Proceeded to burn the DVD and again an error at 50%. I don't have the error log and was going to try a test burn to provide one but I heard that test burns do not work with DVD +R DL media.
    I do have a screenshot of the error I received though.
    Use Verbatim double layer media (on sale at Best Buy this week), not Memorex.
    I used to own that exact same drive, the Sony DRU-810a, and it had trouble with the layer break. I bought a pack of 25 of Memorex, and I had, I believe it was 12 or 13, that would either choke on burning the layer break or would fail to read it back to me past the layer break. No more problems after switching to Verbatim.
    EDIT: added some stuff
  3. Member victoriabears's Avatar
    my story is that I have any dvd installed and used Nero copy dvd option to memorex DL 2 x 4., could not believe Nero would copy just like that.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
    Gatsu,
    I agree with BoilerUp that changing to Verbatim will probably solve your problem.
    Another bit of advice...don't use a DL ISO created by DvdShrink as it doesn't do it properly. I would also recommend you stick with ImgBurn, especially for dual layer burning.
    You're right that you can't do a "Test Mode" burn using +R media. You'll get a real burn.
    Welcome to VideoHelp.
    Thanks for the replies. I am going to Best Buy today to pick up some Verbatim discs since they are on sale! Thanks for the heads up on that BoilerUp.
    I would have purchased Verbatim before but I am too cheap!
    Will post the burn result tonight.
    Switching to Verbatim solved the problem. Thanks!
  1. Replies: 7
    Last Post: 18th Nov 2011, 03:16
  2. Dual Layer problem. Layer break issue...
    By papegoja in forum DVD Ripping
    Last Post: 9th Jun 2010, 22:52
  3. Dual layer disc error (2nd layer not burning properly - AVCHD)
    By hhhgamewmx7 in forum Authoring (DVD)
    Last Post: 24th Aug 2008, 09:00
  4. Very Newbie Question: Can I Write Dual Layer?
    By dadada_999 in forum DVD Ripping
    Last Post: 9th Apr 2008, 09:00
  5. dual layer DVD-R in single layer burner?
    By snafubaby in forum Media
    Last Post: 4th Oct 2007, 13:39
