Hi.
Ok here's the situation. I have a couple of movies that I need to get off my comp. but are too big to put onto 1 CD, so I need them in 2 parts. I used a splitter called "Fast AVI Mpeg Splitter", and it does what it says. No loss of quality in the movie, and the sound matches the video. So now the video is in 2 parts.
I burn using Nero 7 Ultra or something, I don't know. Anyways, I make an SVCD to get the best quality (2 passes, 4:3 ratio, 2000kb/s). It burns without any errors. Now, when I playback the movie on my DVD player, the audio slowly gets out of sync with the video. Well, the video happens first, then the sound follows. This happens roughly at about 20mins of both parts of the movie and gets worse. There is no out of sync problems on the two parts on my computer though. Movie is encoded in PAL, and my DVD player supports this function.
So now for the second twist. Another movie I have on my comp is already in two parts. I didn't need to split it. I burnt that using the same options (movie is also in PAL), and the playback has no problems.
Is there anything I can do to fix this problem? Thanks for all the help.
You are basically performing two functions, converting from avi to mpeg and then burning to disc. Your problem is in the conversion stage. Nero sucks at conversion, try a different tool.
Look in the HOW TO - CONVERT section for guides which will help you through the process.
And welcome to the forum.Google is your Friend
Thank you. Why does Nero suck so bad though? I don't understand how 1 movie could work properly, but the other one have issues when I'm burning using the same settings.
I'll search around some more though. Thanks again.
The simple answer is because there is no standard for avi files.
Not too mention that Nero itself is a burning app. If you want to burn discs get a burning app, if you want to convert video, get a video conversion app.Google is your Friend
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 19:02 -
Sync audio playback between 2 computers
By zeek543 in forum Media Center PC / MediaCentersReplies: 2Last Post: 25th Jul 2010, 22:18 -
MKV/DTS video playback out of sync
By johnc10 in forum Software PlayingReplies: 1Last Post: 16th Oct 2009, 15:31 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38
Statistics
Newest guides
Latest tool updates
New media comments
