VideoHelp.com Forum
Results 1 to 10 of 10
  1. Member Schlag96's Avatar
    I've got one on ebay but it's a 1980P. Just wanted to see if that's something I should know.
    Hate to see it be like a PAL version or something.
    I have until 4:50 eastern to bid so if anyone knows I'd be grateful.
  2. Member edDV's Avatar
    You didn't check that detail before you bid it?
    P suffex often means PAL
  3. Member Schlag96's Avatar
    I'm checking that detail here with you all BEFORE I bid it.
    I asked the guy but it's a store so I don't expect a response in time.
  4. Member edDV's Avatar
    Hit Google. Look for spec sheet.
  5. Member Schlag96's Avatar
    I'm not an idiot. Can someone post who has one of these or knows the answer to my question?
    The only thing google had on a 1980p was a place to buy the manual, not the manual itself.
    OK how786 had a post where he said he had a 1980p. so if he lives in the US I can assume it's not pal. anyone know?
  6. Member edDV's Avatar
    I located a few in the US but can't confirm standard. Have you considered calling Panasonic?
  7. Member Schlag96's Avatar
    I have 17 minutes till the auction ends I'm gonna try
    Wish me luck lol
  8. 8 minutes to go. . .
    The 1980P is a slight upgrade on the 1980. I have the 1980P, and it's a magnificent piece of work. It is not PAL.
    Good luck!
  9. Member Schlag96's Avatar
    Good luck!
    Awesome!
    Thanks I found both manuals on the panasonic site, but there was nothing in them easily found om what format they were
    EDIT: OK I won it for 177.50 including shipping. Everyone cross fingers that it really does work "great" as described
  10. Mod Neophyte Super Moderator redwudz's Avatar
    Schlag96, your signature is violation of our rules. Please change it. Our rules:
    Signatures
    Max 3 lines text using font size 12(bbcode font=Normal) or smaller and using forum width 680 pixels.
    Max image size 400x60 and max file size 10kbyte.
    http://forum.videohelp.com/viewtopic.php?t=124514
    Thanks,
    Moderator redwudz
  1. Panasonic 1980p as passthrough TBC
    By magillagorilla in forum Restoration
    Last Post: 4th Dec 2011, 18:56
  2. Replies: 4
    Last Post: 4th Apr 2010, 07:49
  3. Panasonic AG-1980P and TBC Questions
    By icon in forum Restoration
    Last Post: 19th Dec 2009, 23:34
  4. AG-1980 and AG1980P - Difference?
    By WhitePhantom in forum Restoration
    Last Post: 11th Sep 2009, 13:04
  5. Panny 1980 vs JVC 9911 vs ???; what's your preference and why?
    By videobruce in forum Newbie / General discussions
    Last Post: 6th Jul 2009, 13:15
