how to convert dvdrip avi's to vcd
i have various dvdrip movies usually measuring around 700mb they are all avi;s and i want to convert and burn them to vcd, i have tried various converters including boilsoft avi converter, Apex.Video.Converter.Pro.v5.32, WinAVIVideoConverter, Allok AVI to DVD SVCD VCD Converter. they all convert these avi's to mpeg1 to burn to vcd's but the size of these mpeg's is usually around 1Gb which is impossile to burn to vcd.
Is there any software or trick to convert and burn dvdrip movies to vcd's i have to give these files to someone who has a vcd player so any other conversion format is out of question.. can anyone help??
VCD is a fixed bitrate @ 1150 kbps. You can fir 80 minutes to one VCD.
You can lower the bitrate (but no(?) oneclickwonder tool will give you that option) to squeeze more to a CD at the cost of even lower quality. Read up on AVI to VCD under Convert left.
I guess the rest of the replies will be: "Forget about VCD - get a DVD burner!"
/Mats
Most commercial VCDs split movies over 2, or even 3 discs.
TMPGENC will let you cut MPEG1 if you don't have another way.
You can author with VCDEasy or VCDGear.
(These all have free versions.)
If your movie isn't too long, you might look for extra large capacity CDRs. Here I can find up to "99 minute" size. These are non-standard, but play on my DVD player.
..and if your burner supports it. My writer only allows me 89.something before erroring out.Originally Posted by AlanHK
/Mats
hey i recently had a ton of problems doing this than i got a program off the net called allok avi to svcd
it works awesome give it a shot!
He/she already hasOriginally Posted by AeR0
http://members.dodo.com.au/~jimmalenko/TMPGEnc1CD.htm
http://members.dodo.com.au/~jimmalenko/EazyVCD1CD.htmIf in doubt, Google it.
I used Nero 6 and I never convert .avi files to any other format. If u have 699MB .avi file, write it as video cd with nero 6 to 700MB empty video cd. Then nero will automatically encode the movie and will burn it to the cd. This burned cd can be played on any vcd or dvd player wthout any problem.
I did this process today....
best regards,
Dilan silva.
I doubt that the OP cares any longer, after nearly 2 years!
Batch convert of AVI's to AVi's to reduce size
By sparker366 in forum Video ConversionReplies: 6Last Post: 26th Feb 2007, 20:54 -
Burn VCD from DVDrip and so on...
By Arduinna in forum Newbie / General discussionsReplies: 2Last Post: 15th Oct 2002, 14:45 -
How convert DVDrip DiVX AVI file with Subtitle to VCD ?
By k01 in forum Video ConversionReplies: 1Last Post: 16th Apr 2002, 05:57 -
.avi dvdrip to vcd best way to convert help plz
By goonie007 in forum Video ConversionReplies: 1Last Post: 21st Mar 2002, 12:47 -
How can I convert a VCD Mpeg to sequential AVI's?
By imdanwhou in forum Video ConversionReplies: 0Last Post: 12th Dec 2001, 07:29
