VideoHelp.com Forum
    Tried playing a dvd disk with DivX movie burned on it, get "Bad Disk" error.
    I tried several disks all the same - Standard dvd movies play fine.
    I also have a Phillips DVP642, plays them all fine (Great player).
    I purchased 2 SD-3990, both give error.
    - Did I get a couple dud players?
    Burnt files using Nero
    Files are placed into seperate folders. Any ideas??
  2. Member Krispy Kritter's Avatar
    Most players don't like the files in folders.
    Most likely you are having a media issue. From the specs, this player does not support +R media. Although it could also be a brand/type issue.
    Google is your Friend
    I'll try a few other disks......
    I have used all DVD-R disk with the majority being Ridata, I do have a few other brands mixed in - I'll try and see what happens......
    thx
    Tried another dvd with folders - same bad disk
    tried a cdr with just 1 file (no folder) - player showed file, should work.
    so I guess it will have to go back to the store
    - too many disks with folders.........
    any recomendations on players with divx that will do folders....
    - looking for inexpensive... just for bedrooms.
    thx again for the assist
  1. Toshiba player disk error
    By Buzzword in forum DVD & Blu-ray Recorders
    Last Post: 23rd Oct 2009, 11:40
  2. Replies: 22
    Last Post: 12th Aug 2009, 11:05
  3. H264 in vdub giving me an error.
    By SignedupGuest in forum Newbie / General discussions
    Last Post: 1st Jul 2009, 09:23
  4. Gui for Dvd Author keeps giving fatal error
    By BobT in forum Authoring (DVD)
    Last Post: 7th Sep 2007, 12:10
  5. Toshiba SD-3990 DVD Player Tray Will Not Open
    By TufrThanu in forum DVD & Blu-ray Players
    Last Post: 22nd Aug 2007, 02:35
