I have a Apex 500 (heh.. from what I've read on this site it seems everyone seems to get a different model.)
Mine plays VCD's, and XVCD's, though, like the box says.
I've read that there are like some sort of limitations to how much a DVD player can handle when playing a XVCD.
I burned Terminator 2 @ 640x288 (this was the resolution the AVI file was in) on 2 cds @1150 bit rate (again, should this be higher? I read that I need a certain bitrate for a higher resolutions to work right.)
I use TMPGEnc for encoding. I've read this site on how to do so.
Well, the story is that Terminator 2 works fine (even though my DVD player zooms in a bit to fit the aspect ratio of the television, and zoom out doesn't want to seem to work.. heh).
Anyway, I burned another movie, it's resolution was 592x400 (also at a 1150 bitrate). I like keeping the orig. resolution, so that way it looks better...
However, when I try to play it on my DVD player (works fine on comp, ofcourse) it grables and skips and has a real hard time (ie it doesn't work right.
So, my question is, is this caused because I didn't use a high enough bitrate for that resolution,
or,
is this the problem?
640x288=
184 320 pixels
592x400=236,800 pixels (ie it's having to calculate more pixels/sec)
and the DVD player reached it's "maximum" bandwith or something for reading XVCD's (Sorry if my use of the tech. language is a litte loose
Should I just trim and stick to stnd. VCD maybe? Hrmmnn...
Any comments would be appreciated,
Medieval
Results 1 to 1 of 1
How to remove or disable area limitations on Sony DVD player?
By coody in forum DVD RippingReplies: 22Last Post: 25th Feb 2012, 03:21 -
LG dvd player model LH T3602ME
By cinemiracle in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th Jun 2008, 02:20 -
AWA Portable DVD player Model LMD-2808
By Leon41 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Jul 2007, 06:12 -
tevion hi fi with dvd player model TMHF910 from aldi (hack?)
By jgalvao in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th May 2007, 10:19
