VideoHelp.com Forum
  1. Member Snakebyte1's Avatar
    Hi..
    I'm trying to help out a friend who has a Sony HDR HC3 Camcorder. When connected to WinXP SP2 via USB, Windows recognized as a Sony USB device but asks for a driver. There is no driver disk that comes with this unit, and Sony does not have any to download. Tried it on two different machines (Both XP PRO SP2) with same results.
    A Google search has found a few other HDR HC3 owners with a similar problem, however, some of the solutions posted, such as re-installing SP2 and looking for a missing MSTAPE.INF file didn't pan out. Also, we tried, as was suggested at http://hdvforever.com/hdv/hdrhc1/fre...re/default.htm, to go under Add New Hardware and manually add the driver from Sound, video and game controllers but there was no SONY listed under manufacturer.
    We are trying to connect via USB in order to transfer over some JPEGs. I'm told that when connecting via Firewire in order to trsnsfer over video (Std Def) similar problem occurs.
    Are their any Sony HC3 (or similar model) owners out there that have run into this? Any ideas on how to get this camera recognized?
    D.
  2. Member edDV's Avatar
    Start with
    http://esupport.sony.com/US/perl/mod...l=HDRHC3&LOC=3
    P-80
    No driver needed to read files on a memory stick.
    Is this not working?
    http://www.kiva.org/about
  3. BuskerAlley.com zoobie's Avatar
    There's a forum at www.dvinfo.net on this cam (I just bought a new HC1)...trubble is, the site's broken and doesn't allow signups. Perhaps there's a thread, though, on your problem.
    PS - Maybe someone could point to other forums on the HC1/3/5/7?
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
  4. Member Snakebyte1's Avatar
    Thanks for the replies...
    We'll check out that forum and see if anything interesting is found.
    As for the reading memory stick files, no joy on that either.
    I know it is not SUPPOSED to need any additional drivers, I'm just trying to convince Windows of that
  5. Member edDV's Avatar
    You should also be able to read the flash Memory Stick Duo in a flash card reader. The adapter may be needed.
    http://www.camerahacker.com/Digital/MS_Duo_Access.shtml
    http://www.amazon.com/Sony-512-Memor.../dp/B0002Z4572
    This adapter works directly with the Duo
    http://www.play-asia.com/paOS-13-71-...en-70-ps2.html
  6. Member Snakebyte1's Avatar
    Hi..
    The problem was a missing MSDV.SYS file.
    D.
  1. Sony HDR-HC3 - HDVSplit or winDv?
    By jefftaz in forum Newbie / General discussions
    Last Post: 20th Jan 2011, 14:10
  2. Sony HDR-HC3 HDV Capture
    By plugh in forum Capturing
    Last Post: 9th Aug 2009, 23:15
  3. Replies: 9
    Last Post: 4th Mar 2009, 12:57
  4. I have a deal for a Sony HDR-HC3 for 350$ CDN, need quick advice
    By DavidOBE in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Dec 2008, 12:35
  5. Sony HDR-HC3/damaged Firewire port
    By alegator in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Jan 2008, 22:08
