VideoHelp.com Forum
    Ever since I installed the newest version 2.1.2474, everytime I try to create a menu with pictures and a colored outline, I keep getting the following error read out:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at x3284ccece41ee22b.x210ff09a2516b1a7.x00f758395e988 eed(String xd397bb1e465ce45e, String x9472539ef71e166c)
    at x3284ccece41ee22b.x210ff09a2516b1a7.xb4ff3ab1ae902 6aa(Int32 xbcea506a33cf9111, Int32 xffd6352b2e5d70e3)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.1.2474.30185
    Win32 Version: 2.1.2474.30185
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
    System.Windows.Forms
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    DevComponents.DotNetBar
    Assembly Version: 5.9.0.0
    Win32 Version: 5.9.0.2
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    Accessibility
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
    Interop.QuartzTypeLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
    Interop.DexterLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
    Interop.NEROLib
    Assembly Version: 1.4.0.0
    Win32 Version: 1.4.0.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.NEROLib.DLL
    CustomMarshalers
    CodeBase: file:///c:/windows/assembly/gac/custommarshalers/1.0.5000.0__b03f5f7f11d50a3a/custommarshalers.dll
    System.Management
    CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
    AxInterop.MSWEBDVDLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.MSWEBDVDLib.DLL
    Interop.MSWEBDVDLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.MSWEBDVDLib.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
    Any help you could give me would be greatly appreciated! THANKS
  2. When in the process does the error occur? Is a log file generated and can you post it?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    System.Runtime.InteropServices.COMException (0x80040154): Class not registered
    at System.Windows.Forms.AxHost.CreateInstance()
    at System.Windows.Forms.AxHost.GetOcxCreate()
    at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
    at System.Windows.Forms.AxHost.CreateHandle()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.AxHost.EndInit()
    at x7e1db0a25be2d2e3.x489133afb8bd5ca0.x85601834555fb 7d5()
    at x7e1db0a25be2d2e3.x489133afb8bd5ca0..ctor()
    at x3284ccece41ee22b.x210ff09a2516b1a7.x3bae72ab2c7b4 5fc(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at DevComponents.DotNetBar.SideBar.OO(BaseItem 74Z)
    at DevComponents.DotNetBar.BaseItem.RaiseClick()
    at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
    at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
    at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
    at DevComponents.DotNetBar.SideBarPanelItem.InternalM ouseUp(MouseEventArgs objArg)
    at DevComponents.DotNetBar.SideBar.OnMouseUp(MouseEve ntArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.SideBar.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    mscorlib
    SVCD2DVD
    System
    System.Drawing
    AxInterop.CodeLock
    System.Design
    Accessibility
    System.Xml
    Interop.CodeLock
    Interop.DexterLib
    System.Management
    Microsoft.VisualBasic
    Assembly Version: 7.0.5000.0
    Win32 Version: 7.10.6001.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
    Interop.NEROLib
    CustomMarshalers
    enabled.
    For example:
    <configuration>
    </configuration>
    As well as the menu problem creation wise i get this message when trying to preview one.
    I get the same error message when trying to preview. I am able to select Continue and the preview window shows my menu - but the text of the highlighted item looks garbled.
  1. trouble with SVCD2DVD menu selection highlighting
    By bobarnett in forum SVCD2DVD & VOB2MPG
    Last Post: 4th Sep 2011, 14:59
  2. SVCD2DVD Error when encoding menu??
    By gsmb in forum SVCD2DVD & VOB2MPG
    Last Post: 23rd Feb 2011, 13:44
  3. Really strange SVCD2DVD menu problem
    By denali in forum SVCD2DVD & VOB2MPG
    Last Post: 4th Oct 2009, 11:41
  4. svcd2dvd problem
    By dvds2u in forum Newbie / General discussions
    Last Post: 27th Mar 2008, 11:05
  5. SVCD2DVD problem with TS files
    By rickfaldo in forum SVCD2DVD & VOB2MPG
    Last Post: 26th Dec 2007, 11:14
