I saw the Sony HC7 at this site and the camcorder has me excited. I see Amazon.com are taking pre-orders here http://www.amazon.com/Sony-HDR-HC7-D.../dp/B000M3HVLQ
Now I am in Europe most of the time and the TV only shows PAL (yes I know it is crap but I am waiting on 1080p screens falling in price).
Do I need to consider the NTSC/PAL issue with a HD camcorder? Or is that issue only for SD?
Thanks in advance to those who may know.
BTTT
It will appear from here http://en.wikipedia.org/wiki/High-definition_television that PAL/NTSC belong to the world of SD only.
Well, yes and no (plus that article has some technical errors).Originally Posted by ArthurDaley
The frame resolutions may be the same, but the frame rates are different.
Also, the EBU's prefered HD format is 720p50 ( http://www.digitalspy.co.uk/broadcas...ion-guide.html )
According to Sony ( http://www.sonystyle.com/is-bin/INTE...me=specs&var2= ), the camcorder you mention records 1080i - but what frame rates?
I'd make sure that the TV you plan to get supports the frames rates from this camcorder.
And, what about import duty?John Miller
enosoft - high performance tools for music and video
Home of the Enosoft DV Processor - Free for personal use!
Crap. I thought this regional nonsense was over in a globalised world? So you reckon frame rates may differ between UK and US versions?I'd make sure that the TV you plan to get supports the frames rates from this camcorder.
Never paid it and I travel to and back from the US often with gear. If I am paranoid I throw the box away before leaving the US. [/quote]And, what about import duty?
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum CapturingReplies: 2Last Post: 17th Jan 2009, 14:36 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 17:19 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 21:45 -
HDV PAL/NTSC considerations
By shaibt in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 15th May 2008, 17:23 -
Pal and NTSC Camcorder
By NightFire in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 20th May 2007, 20:01
